Oultlook 2007 Signatures
I found the way per what you gave me earlier, to make the words bold, but the areas to create the line space does not do it, and anything else I type is bold, rather than not bold...
So is there a way to create the line spaces and only bold the automatic words...and would like to hear back from the SMART WOMAN!!!! :D
:D:D:D
Here is the two different ways I did it per the earlier code and then how you showed me to do it as one line re the words:
Public Sub E_Mail_From_Dad2()
Set oContact = GetCurrentItem()
Dim objMsg As MailItem
Dim sMsghtmlbody As String
' Blank message
' Set objMsg = Application.CreateItem(olMailItem)
objMsg.HTMLBody = vbCrLf & vbCrLf
objMsg.HTMLBody = objMsg.HTMLBody & "<B>Love You,</b>"
objMsg.HTMLBody = objMsg.HTMLBody & vbCrLf & vbCrLf
objMsg.HTMLBody = objMsg.HTMLBody & "<B>Dad</b>"
objMsg.To = oContact.Email1Address
objMsg.Subject = "From Dad"
objMsg.BodyFormat = olFormatHTML
MsgBody = objMsg.HTMLBody
'displays the message form so you can enter more text
objMsg.Display
'use this to send to outbox
'objMsg.Send
Public Sub E_Mail_From_Dad3()
' Blank message
objMsg.HTMLBody = vbCrLf & vbCrLf & "<B>Love You, </b>" & "<B>Dad</b>"
objMsg.Display
'objMsg.Send
Thanks again so much....I ran what you showed and if you take out the p stuff, the space is not the same before the first work line....so I kept that in...and between the the two word lines, there was not a line space so I tried the following and it creates the line space between the two line.....so the only last thing to fix on this, is after the last work line when I hit enter to type in words below it, it's bold...so is there something at the end of the HTML line that makes sure that the next word line after it is not bold!!
objMsg.HTMLBody = "<br /><p><b>Love You, <br /><p><b>Dad</b></p>"
1) you didn't end the bold tag around "love you" - </b> - you should always use closing tags - outlook *should* add it for you to create proper HTML, but it's good practice to use it.
2) when you press Enter at the end of a line, outlook assumes you want to continue to use the formatting of that line. Add a <br /> (line break) at the end so the new line is ready to use.
Thank you so much.
So if there is a line break at the end, the words after that are not bold?
And is this the code as not sure re the <p> at the end or before the line break.
objMsg.HTMLBody = "<br /><p><b>Love You,<b> <br /><p><b>Dad</b></p><br />"
Here is what I did per your advice, and it adds a new line automatically.....and the words I type in are not bold....thanks so much as usual!!!
Thank you so much.
it's not so much that there needs to be a line break, but that you need a new line inserted that does not have formatting. The closing b (</b>) ends the formatting but when you start a new line, outlook uses the same formatting as the current line. Because the last character is bold, it's carried over to the next line. If you had a character after the bold part, a new line should be normal font. IMHO, i think its easier if there is a blank line at the end though.
As I said, what you gave re the line break works perfectly!!! It's easier.:)
And if you can, look at the new post I just did to figure out how to use a macro that opens up a subfolder which is under the Contact folder...I just posted it and the code someone showed me but it is nothing so far!! Just in case you know..it will be fast...as in the contact form, after I have a list of these macros, I can create droplist as I did before to go to the correct folders etc....thanks so much!!
B Oultlook 2007 Signature back ups Using Outlook 4
B Outllok 2007 License Expired issue Using Outlook 0
Steven 2007 New PC vs Old PC - Micro Font on Inbound Emails :( Using Outlook 4
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
