Attachment Icon (paperclip) not showing for some emails with Attachments
pagema
We are on Win7 - Outloo2010. I have some users that are receiving emails with attachments, but the paperclip is not showing. It isn't for all messages, just some. When opening the email, the attachment is there. I have read where it isn't appearing at all, but this is not the case. It is just certain messages that it is not appearing for. Anyone have a solution to resolve this.
larry
This is usually the result of a virus scanner or the sender's SMTP.
Are the messages HTML or RTF format?
larry
Doesi t only happen with one kind of attachment, like all .doc files are affected but not other files?
Commodore Attachment icon when there is no attachment Using Outlook 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
P File Picker for attachment Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
N File Picker for attachment Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
B Outlook 2010 Opening Mail Attachment Using Outlook 2
A Warning When Opening attachment Using Outlook 7
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
N Macro for attachment saved and combine Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
M Search for attachment filename Using Outlook 0
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Vijay Reply all by attachment name Using Outlook 10
Michael R Belleville Making an Attachment Name the Message Subject Using Outlook 2
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
P Outlook Randomly Not attaching (attachment file) Using Outlook 0
S VBA to search a keyword in attachment and move to a folder Outlook VBA and Custom Forms 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error Using Outlook 0
