UserForm Code For Contact Links
Thank you. I looked at it and I believe that is not the way to upgrade. One other question just in case you think this makes more sense.
In the current code as to:
For Each fldr In objFolder.Folders. It is the subfolders
And
For Each flder In fldr.Folders. Its the subfolders of the subfolders.
So specifically, what to add so its the subfolders of the subfolders of the subfolders? As this would go thru the third level subfolders.
Thanks very much!
Here is what I updgraded as I posted next (as there is a limitation on the number of letters in each post), and it takes care of the third level subfolders
Private Sub ddlCategories_Change()
Dim objFolder As Outlook.MAPIFolder
Dim ctc As ContactItem
Dim FolderName As String
Dim fldr As Folder
Dim flder As Outlook.Folder
Dim flderr As Outlook.Folder
Dim myContacts As Outlook.items
Dim Category As String
Category = Me.ddlCategories.Text
Set objOutlook = CreateObject("Outlook.Application")
Set objFolder = objOutlook.Session.GetDefaultFolder(OlDefaultFolders.olFolderContacts)
Me.ddlContacts.Clear
If objFolder.Folders.Count > 0 Then
Set myContacts = fldr.items.Restrict("[Categories] = '" & Category & "'")
If myContacts.Count > 0 Then
myContacts.Sort "[Fullname]", False
For Each ctc In myContacts
Me.ddlContacts.addItem ctc.FullName
Set myContacts = flder.items.Restrict("[Categories] = '" & Category & "'")
For Each flderr In flder.Folders
Set myContacts = flderr.items.Restrict("[Categories] = '" & Category & "'")
Private Sub UserForm_Initialize()
'The loads the Outlook userform and populates the combobox of contact folders.
Dim Category
For Each Category In Application.Session.Categories
Me.ddlCategories.addItem Category
Private Sub ddlContacts_Change()
'This opens the contact form for the contact selected.
Dim ctcItems As Outlook.items
Dim ctcFolder As Outlook.MAPIFolder
Dim ContactName As String
Dim FoundFolder As Outlook.Folder
ContactName = Me.ddlContacts.Text
Set ctcItems = fldr.items.Restrict("[FullName] = '" & ContactName & "'")
If ctcItems.Count > 0 Then
Me.Hide
For Each ctc In ctcItems
ctc.Display
Set ctcItems = flder.items.Restrict("[FullName] = '" & ContactName & "'")
Me.Hide
ctc.Display
Set ctcItems = flderr.items.Restrict("[FullName] = '" & ContactName & "'")
Me.Hide
ctc.Display
Private Function FullFolderName(ByVal FolderName As String) As Outlook.Folder
End Function
Now also, when the contacts list shows up, they are sorted alphabetically per each subfolder they come from....so is there a way to show them all alphabetically as if from just one folder?
And
wouldn't it be like this:
For Each whatever In flder.Folders
No, not when you do one folder at a time.
Because its so difficult to do anything with the things in separate folders, outlook mvps always recommend using fewer folders and categories.
Thats what i did per what i showed above. And had to add a few other things re the other areas.
So anything on the sort all per alphebetically?
You'd need to read the folder contents into an array then sort the array. It can be very slow if you have a lot of records. And i don't have any code samples - most are for excel workbooks.
http://vbaexpress.com/kb/getarticle.php?kb_id=103 has an example, but you need to create an array.
This is one way to create an array. (report is the array)
Public Sub ListContacts()
Dim Report As String
Dim ContactFolder As Outlook.folder
Dim currentItem As Object
Dim currentContact As ContactItem
Set Session = Application.Session
Set ContactFolder = Session.GetDefaultFolder(olFolderContacts)
For Each currentItem In ContactFolder.Items
If (currentItem.Class = olContact) Then
Set currentContact = currentItem
If ("Full Name" <> "") Then
Report = Report & """" & currentContact.FullName & """, "
Debug.Print Report
Thanks so much. Where do i put the code you gave me regarding the code i use!
I have no idea. :) It's just a sample to should you how to do it. I'm not sure it will be the most efficient with a lot of folders.
this is the meat of the code - you'd walk each folder and add to the array. But like i said, it's probably going to be very slow if you have a lot of folders and contacts.
Got it! Happy to get a sugestion you might think about.
As to referring to the to Contact folder and not subfolders.....as to the following code, instead of referring to "For Each fldr in objFolder.Folders", how do I refer to the standard Contact folder ....so I can categorize contacts in the Contact folder as well...fo purposes of my list
Set myContacts = fldr.Items.Restrict("[Categories] = '" & Category & "'")
Thanks very much....if you look at my full code, where do I put this as there is that place where it is the subfolder(s) process and not sure do I put that in there...or above it?
I emailed you the full code and explained how there are two places...as the contacts from the cagegory and the link to the contacts later in the code...if you can, plesae read my email as its two large to post
I just emailed you the entire new code that I figured out and it does it all......so the only thing left is the sorting by alphabetical across all category lists and all contact list that shows up.....so if you look at my big email, you can understand how I used a portion of what you gave me and everything else I changes or added....and again, so the only thing left is the sorting by alphabetical across all category lists and all contact list that shows up
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
A Outlook Userform Size Outlook VBA and Custom Forms 2
N Activity Tracking with Userform Outlook VBA and Custom Forms 4
D Next Available Meeting with Userform Variables Outlook VBA and Custom Forms 1
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
A Open CHM file from VBA Userform Outlook VBA and Custom Forms 4
L Outlook 2007 - Userform Using Outlook 2
A Focus on the userform Outlook VBA and Custom Forms 15
F Outlook 2010 - outlook userform and combo boxes Using Outlook 9
L Userform Field Month and Date. Using Outlook 19
Witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
X VBA: Confused with variables between ThisOutlookSession and UserForm Using Outlook 1
M Progrescreas Bar in Outlook UserForm Using Outlook 1
C UserForm and ordering variables Outlook VBA and Custom Forms 3
J userform combobox Outlook VBA and Custom Forms 1
R combobox list in userform Outlook VBA and Custom Forms 1
B Userform Outlook VBA and Custom Forms 5
W Using Excel UserForm from Open Workbook in Outlook VBA Outlook VBA and Custom Forms 5
P userform in VBAProject.otm not working Outlook VBA and Custom Forms 1
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
