Manual archive of select folders
Zorak
I think I know the answer to this but would just like some confirmation.
I want to archive manually, not auto. However, I will only want to archive select folders in my Inbox. Since the manual archive does not let me select multiple folders to archive, I have to do multiple archiving cycles to get them all. And just selecting the Inbox gets all the subfolders as well, which would include folders I do not need archived and thus need to be moved back out.
But if I went to the folder's properties and to its auto archiving tab and select 'Archive items in this folder using the default settings' BUT do not enable autoarchiving in the default settings, I could then in the manual archive select 'Archive all folders according to their autoarchive settings' to manually archive only those folders I had set to autoarchive.
The question is would this work as I hope? And would some sort of autoarchiving still take place because I am using the default autoarchive settings for a given folder but just have not told it how often to autoarchive, so it therefore picks some default time span to do it?
Is that clear as mud?
Thanks in advance.
Z
Well, I think I have my own answer in that it will not work. Once you select the use of autoarchiving in the manual archive window, you no longer can pick the starting date and it goes to the auto archive settings which is a time frame, i.e. older than 6 months, rather than a date older than.
I have a new thought on organization of my folders that will probably be a better route to go anyways.
Z
A manual rule sends mail to wrong folder Using Outlook 5
P Manual Archiving 2016 Using Outlook 7
I outlook 2016 manual exchange config Using Outlook 0
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
R Different behavior AutoForward with Rule vs manual forward. Using Outlook 0
kburrows Online Archive - Do Not Archive Tasks Using Outlook 1
L Why are some email automatically going to "archive" Using Outlook 2
HarvMan Archive Email Manually Using Outlook 1
P How did hacker cause link to delete and archive containing email? Using Outlook 6
D Archive by receive date not working Using Outlook 2
GregS Can't access archive file Using Outlook 5
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
S Moving Emails Between Archive Folders Using Outlook 1
M Multiple spurious empty folders appear in archive files Using Outlook 3
P Can't search Archive'd Tasks Using Outlook 0
C Merge two archive calendars Using Outlook 1
B Relocating archive.pst file Using Outlook 6
R Enable Office 365 Exchange Online Archive Using Outlook 0
R Enable Office 365 Exchange Online Archive Using Outlook 6
A Does Outlook import Gmail Archive? Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
K Different kind of issue related to creation of archive after one has been deleted Exchange Server Administration 1
skylark53 Archive a single Outlook 2013 folder tree Using Outlook 5
L Archive Shared Folders for all to Share Using Outlook 0
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
Jennifer Murphy Difference between export and archive? Using Outlook 10
D I can’t access my archive.pst Files Using Outlook 2
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
G archive attribute for email attachments Using Outlook 2
S Create rule to effect archive only Using Outlook 4
O Importing pst, archive pst and address not working Using Outlook 17
J Auto-archive with Exchange account Using Outlook 2
D Add data in archive.pst to outlook.pst Using Outlook 4
J Outlook 2007 Archive Using Outlook 1
R [outlook-users] Messages won't archive Using Outlook 5
R Custom Archive code -- modify my code! Outlook VBA and Custom Forms 3
S Archive bit in email messages? Outlook VBA and Custom Forms 3
U "archive.pst cannot be opened" when archiving Using Outlook 4
