What is BCM written in?
Outlook 2013 32 bit
Other than the Sql 2008 component, what is BCM written in? I'm beginning to be of the mindset the only way I will get what I want need is to do it myself (or hire someone to do it for me.) However I'm at a loss as to what language BCM is written in. Can someone help with this information?
Michael
Is the forum working right for you? I'm getting errors and other weird behavior when i hit Post Quick Reply.
Outlook 2013 32 bit
I have also gotten errors when I attempt to reply. It tells me I am attempting to post a duplicate post even though I had not posted the reply.
  • This post is a duplicate of a post that you have posted in the last five minutes.
But it is posting...
Yea, that is the error I'm getting. It seems like its only happening with replies to you. :) It stopped for a few replies and is back again. :(
All I will say is that it's not just Microsoft that is afflicted by bad security updates - these problems started when i installed an update that addressed a serious exploit.
Outlook 2013 32 bit
Great! Only in replies to me... Kinda sounds like the way Outlook/bcm is (not) working for me today. Following un-installing a few of the various updates are listed in the other thread regarding the bad BCM behaviors, everything in BCM stopped working for me. i.e. anything I clicked on would produce a "Not responding" error and the application never came back. So then I tried re-installing all the updates and then I couldn't use a browser i.e. whether Chrome, IE9, Safari, etc. none of them would allow me to type in the address field.
It's looking like I will have to do a full re-install of the OS (again!!!!) tonight to get things working the way they are supposed to.
I'm getting to the point where I think there should be a class action suite against any company that issues an update that creates this much damage. It's only been in the last year or so where I've had such issues with Windows et al. No one should be able to release updates that create more issues than they fix. This is costing me/my company $$$ due to lost productivity. (rant over)
wallisellener
Outlook 2013 64 bit
Concerning posting - same problem here: "This post is a duplicate of a post that you have posted in the last five minutes"
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
