Outlook 2007 Code for Note Fields of Appointment
Thanks so much for your time as usual. I found a different way to do it....I created a new TextBox29 and as to the field, I used the Email field and then as to initial value, used the email field, and in the contact form, it shows the email address in the new textbox and I used TextBox29 in the standard If line, and it automatically shows up in the Calendar Event body field. Thanks again so much!!:eek::eek::eek:
And to All, In Case this Helps, I did the same for the webpage of the contact and that works as well. So on my Calendar Event, I can immediately use the email address of webpage link as well. and both also show up in my Iphone which syncs to the Outlook.
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
