Outlook 2007 Delete and Paste Between Fields
I have tried to go thru it but it is not clear to me how to change the UserProperties fields.....any way to do it?
And I would expert you know the way to refer to Userform fields instead of "File as" and I would think there are the Dim areas to add...the objItem areas to add to the code so it simply changes a Userform field to another Userform field....but I have no idea how to do it!!!
I went to the Body field and changed the following and it worked...so it seems to me there should be a way to change the Dim area and these other two lines for changing a Useform field to another Userform field.
Dim strBody As String
strBody = ""
> Body = strBody
Any update today as I can finish all of the custom fields when I know the code. Thanks so much!
To All Again: The following code I found the way to do it, will move the words that are in the custom field of the contact, to another custom field, and based on what I asked, I also found the way that the code will work for all contacts that are selected....so if you need to move the words from one custom field to another custom field in many contacts that are selected in a folder, this works. And to be clear, this code moves the words from First Status: to Status3: and turns First Status to an empty custom field.
Sub ConvertStatustoStatus3()
Dim objApp As Application
Dim objNS As NameSpace
Dim objFolder As MAPIFolder
Dim objItem As Object
Set objApp = CreateObject("Outlook.Application")
Set objNS = objApp.GetNamespace("MAPI")
Set objSelection = objApp.ActiveExplorer.Selection
For Each objItem In objSelection
objItem.UserProperties("Status 3:") = objItem.UserProperties("First Status:")
objItem.UserProperties("First Status:") = ""
objItem.Save
Set objItem = Nothing
Set objFolder = Nothing
Set objNS = Nothing
Set objApp = Nothing
L Outlook 2007 Delete Email Addresses Using Outlook 19
S can't delete duplicate account under Outlook 2007 (Win 7) Using Outlook 16
L How can I delete stationery from Actions, New Mail Message Using in outlook 2007? Using Outlook 6
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
S How to view backed up PSTs from Outlook 2007 in Outlook Classic's Folder pane Using Outlook 11
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
