Incoming invites to my imap account does not sync to outlook.com
They are working on a number of things to make Outlook.com better but I'm not sure about this issue. I'll see what I can find out.
If you add a note to the body or add a category, will it sync it?
Chuckk9032
Outlook 2013 32 bit
I tried that, but it doesn't work, either.
Strategus
Outlook 2013 64 bit
Ugh.
I'm having this exact same problem, having just "upgraded". Very frustrating.
Has there been any progress on a solution?
Karel
Outlook 2013 64 bit
I see that the last reply is fro last July. Is there any solution to this. I have it on my desktop exactly as described by Magnus and it is driving me crazy. Is there any solution?
Meeting requests are a problem - sometimes they will sync if you add a category or some text in the note field and save. They are working on some improvements but I have no ETA - I'm not expecting it anytime soon though.
Karel
Outlook 2013 64 bit
Hi Diane, Thank you for following such old post. The categories do not make any difference for me. So far anything I do with that appointment does not make any difference in making it sync. Because it is such a specific issue (it only happens to invites through outside e-mail), I imagine that it shall be relatively straightforward issue. But I guess someone in MS would have to care.
As it is this alone issue makes Outlook useless for people with external e-mail. If I cannot count on Outlook to sync appointments, I am asking for trouble to overschedule or miss appointments. I am mostly out of office, and if I cannot trust Outlook to sync my appointments with my phone it is useless.
Using outlook e-mail does not work for business users with their e-mails and it seems that there is no other workaround.
Let me know if you know of a solution how to get around this issue.
It's not a good situation, but it's also not simple to fix. They are working on a solution for this and a whole host of other issues. If you forward the meetings to outlook.com and accept them in outlook.com, it should work.
MotoMike
Outlook 2013 64 bit
Outlook.com (as MS Exchange)
Is there any update on this issue? I am having the same problem with a similar setup. Running Outlook 2010 on one PC and everything works as expected. On the Surface where I am running Outlook 2013, incoming meeting invitations appear to go to the right calendar, but they do not sync w/ Outlook.com. Contacts are also not syncing properly - they transfer over but then a bunch of duplicates are created.
It's a known issue with EAS accounts. It'll work with 2010 because the connector uses deltasync. It will be fixed when your outlook.com account moves to office365 sometime later this year. When it is moved you'll set up the outlook.com account as an exchange account - the connector will stop working in Outlook 2010.
Patrick Corun
Outlook 2013 32 bit
This thread has not had any responses to it for a while, but since the migration is almost finished for the outlook.com users, I need assistance. I have created a new outlook.com account that is on the new servers (Outlook Mail at the top). My email for work is handled by a local company and I retrieve emails via IMAP. I have the imap account set up and working fine. My outlook.com account was added by entering the simple settings and allowing the automatic configuration in outlook 2013. My IMAP account is set as the default email account and my outlook.com account is set as my default data file. I have migrated all my contacts and calendar items to the outlook.com account and appears to be syncing just fine. Here is my dilemma:
When I create an appointment from a received email in my IMAP account, it added it to the (this computer only) calendar that was apparently associated with the IMAP account. I followed your instructions for removing them from the folder list. This worked fine, but now when I try to add an appointment from and email or accept an invitation, I get the message that the calendar could not be found. I noticed that my outlook.com account is an .ost file. I thought the new server accounts were going to be exchange data files? Anyways, can you help me resolve this issue of not getting all my invites and new meetings to the outlook.com calendar.
Pat.
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
T Search for incoming e-mails for a specified time range Using Outlook 1
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
T Incoming Mail Changes Fonts Using Outlook 0
R VBA to manage incoming mail Outlook VBA and Custom Forms 2
I Capture incoming emails Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
P Use VBA to alert if new incoming email fits criteria Outlook VBA and Custom Forms 0
A Processing Incoming E-mails with Macros Using Outlook 0
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
A Incoming mail not downloading Using Outlook 2
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
S The incoming task is not valid ((when users are accepting a Task) Using Outlook 5
Commodore Unified inbox or incoming messages view Using Outlook 27
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
A Alerts on incoming emails which are not responded since 1 day Using Outlook 1
J Cannot read incoming emails Using Outlook 2
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
J Incoming emails going to wrong sub-folder Using Outlook 4
F How to change all incoming fonts to black? Using Outlook 3
T Unset alerts from incoming email Using Outlook 11
S Outlook incoming mail & color blindness Using Outlook 2
E Creating rules for incoming emails to be forwarded Using Outlook 2
H new incoming email going to CONTACTS folder?!? Using Outlook 2
J Saving Incoming & Outgoing Outlook 2010 Email Locally with IMAP Using Outlook 2
J Why Doesn't some Incoming Gmail Doesn't Appear In Outlook? Using Outlook 9
E Outlook cannot connect to your incoming (POP3) e-mail server/Cannot send mess. Using Outlook 0
