Why won't VBA see a copied calendar in cache mode anymore?
Well, it didn't work. I created new folders in the new mailbox and I carefull copied individual subscriptions and sharing items from the old folders into the new ones (instead of using <ctrl-a> to select them all, so I wouldn't copy something hidden).
It looked promising because the new mailbox was the only shared mailbox that didn't show duplicates in the nav pane when I switched from online to cached mode. I changed the Initialize program to point to the new mailbox, cleared the dups from cached mode using the reset switches, waited until all the folders were updated, and restarted Outlook in cached mode. But the program broke at the same place -- immediately after the CopyTo because the folder variable wasn't set.
I also tried stepping through the Initialize program in cached mode (the one that loops through object stores to assign global variables) and it still exited prematurely as I described in an earlier post -- i.e., the highlight disappeared for a moment and then VB just stopped running, so I couldn't cycle through all the object stores -- albeit at a different point this time. This doesn't happen in online mode, so perhaps something is corrupted at a level above individual folders or mailboxes.
J VBA code (rules) won't work after reboot Outlook VBA and Custom Forms 2
Rupert Dragwater Mail won't show as read Using Outlook 2
icacream New password won't update Using Outlook 2
C Why won't Title display in message list? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
M outlook won't open! Using Outlook 1
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
M other user's mailbox won't open, forms disappeared Using Outlook 42
P Outlook 2016 won't Start Using Outlook 3
Phil52 Outlook won't work Using Outlook 1
N editing drafts - won't let me save Using Outlook 12
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
Jaegel Email Hyperlinks from one source won't open Using Outlook 4
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
A iPhone Contacts in Outlook won't File As First, Last Using Outlook 0
JulieB Default data file won't change Using Outlook 6
B Restoring PST files won't work Using Outlook 1
J Outlook won't open. PST file busy. Using Outlook 3
P Outlook 2007 won't connect Using Outlook 6
S Outlook 2010 won't send on Windows 8 Using Outlook 2
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
K Macro won't consistently re-enable Outlook VBA and Custom Forms 2
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
V Custom form won't open for edit Outlook VBA and Custom Forms 3
C images won't display in email Using Outlook 2
J why won't the automatic send/receive work Using Outlook 7
B icloud calendar stopped syncing, won't restart Using Outlook 1
C Outlook 2010 Address Book, won't stay selected Using Outlook 5
D 2013 BCM Won't Install BCM (Business Contact Manager) 1
R Emails won't come into outlook but can send Using Outlook 0
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
Z Outlook opens minimized, won't maximize Using Outlook 2
J Email won't send Automatically in Outlook 2010 Using Outlook 3
G Outlook 2013 won't download images Using Outlook 6
O Calender first day Sunday won't stay Using Outlook 3
