jump to body in open message with one keyboard shortcut?
igrokit
I know about TAB and shift-TAB and also SPACE/shift-SPACE But please read on.
I like to do as much as possible over the keyboard. But for this, I did not find a shortcut. Is there one?
If I receive a message which has several pages of text, I obviously need to scroll the body part of the open message to read. Yet, if I open a message, the body part is not active. I first have to click into the body part to be able to use the arrow keys or page up/down. I can TAB into the body, but unfortunately, depending on the message type, if it's part of a thread or some other reasons I was not able to figure out, I have to TAB between 1 and 5 times to end up in the body part. Only then I can use the arrow or pg-up/pg-down keys.
If I had the reading pane enabled, I could use SPACE or shift-SPACE. Yet, if I open the message in a separate window, that does not work.
Is there a keyboard shortcut that allows me to directly scroll the body of an open message?
Dan
Try F6 to jump to the message. Oh wait, that might be reading pane. :(
In Outlook 2013 (haven't checked 2010 yet), the body is active when you open the message, if you don't click elsewhere or press the alt key.
Thanks Diane,
Pity... but perhaps a compelling reason to switch to 2013? ;-)
Dan
It might be the only compelling reason. :) Actually, I really like 2013 but a lot of people don't like the blandness, whiteness of it. Once you get past that (turning monitor brightness down about 20% helps) Outlook 2013 is nice IMHO.
Victor_50 Outlook 365 Jump to folder Outlook VBA and Custom Forms 3
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
Victor_50 jump to actual folder from favorite Outlook VBA and Custom Forms 1
F Jump to Inbox folder when click on Favorite Using Outlook 0
T Outlook 2013: How did "Inbox" emails jump straight to the "Recover Deleted Items" Folder? Using Outlook 2
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
B 10 Practical Tips for Healthy and Sustainable Weight Loss10 Steps to Achieving Your Dream Body Outlook VBA and Custom Forms 0
G Retaining Tabs in outlook body Using Outlook 2
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
K Incorporate selection from combobox into body of email Outlook VBA and Custom Forms 0
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
Beeto Replace a string in body Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
