Macro to mark message as junk and delete
7GoldCoins
Exchange Server 2007
I'm trying to do something that should be very simple. I just want to automate two keystrokes. If Outlook 2007 had a macro recorder, this would be trivial, but I have to write the VBA by hand and I'm a neophyte. All I want to do is, for the highlighted message in the inbox, add sender to block senders list and delete. I've looked at a lot of posts and sites and can't seem to find what I need.
Both of these actions are easily accomplished one at a time but I want to string both functions together and assign to a single button. Just a small time saver and dipping my toe into the VBA pond...any help would be appreciated.
7GoldCoins
Thanks for the reply Diane. I'll try send keys. I know most spammers don't reuse their addresses so occasionally I'll go into the list and look for commonalities in their addresses and build a rule based on those commonalities. It's a never ending battle but this was a good excuse to learn a little VBA. Thanks.
R Macro to mark item unread Outlook VBA and Custom Forms 2
