Appointments
I asked you to add a ref to the Outlook library, not Office.
As to the new error, I cannot help if you don't tell us where the error occurs. Every mentioned error is highlighted, please tell us where that is.
So sorry, yes Outlook library is referenced now and I am still getting the same error as the above post. See highlight below.
Ok, that means there is no sheet called "Sheet1". See the project explorer left hand, the line that starts with "Sheet1". You have renamed the sheet, and you can see its name in the brackets.
I don't know what to say anymore.
The loop (Do Until...) reads values from the sheet row by row, then it looks for a subfolder of your default calendar with the name read from the sheet. And the error means that there's a name in the sheet for which there is no subfolder.
Place the cursor over the variable named "arrCal". A little label will come up telling you the current value of the variable. Let's say, the current value is "test". That would mean that your default calendar has no subfolder called "test".
OMG, finally! Thank you so much. I had not created a subfolder in my calendar! Again THANK YOU SO MUCH! Now back to business!
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
M New Calendar Appointments: Conditionally turn off reminder and show time as free Using Outlook 14
M Printing Appointments Using Outlook 1
M Calendar daily Appointments and printing Using Outlook 0
L Option to Show Cancelled Appointments Using Outlook 0
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
F Year-and-a-day recurring appointments Using Outlook 1
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
D hiding appointments that are completed or cancelled, how to ? Using Outlook 5
M warning for too many appointments on a same day in Outlook Using Outlook 1
OutlookIntegrator Appointments Using Outlook 0
R Make past appointments remain in calendar Using Outlook 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
A Outlook.com changing appointments Using Outlook 8
T populate calendar with appointments and send reminders Using Outlook 1
Diane Poremsky Create Appointments Using Spreadsheet Data Using Outlook 0
Diane Poremsky How to Import Appointments into a Group Calendar Using Outlook 0
I Outlook 2013 Appointments not in HTML Using Outlook.com accounts in Outlook 2
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
M Expected behaviour of recurring appointments? Using Outlook 2
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
A Looping appointments in calendar Outlook VBA and Custom Forms 0
B Outlook Calendar/setting appointments Using Outlook 1
L Appointments disappearing Using Outlook 0
N To do bar - show more than 30 days of appointments Using Outlook 0
A Show ALL of today's appointments in To-Do Bar Using Outlook 1
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
S Outlook 2013 Appointments missing Using Outlook 1
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
J Change reminder times of future appointments Using Outlook 1
Mark Rideout Search folder for appointments and emails Using Outlook 2
C Appointments from Excel to Outlook Using Outlook 3
C Appointments Exchange Server Administration 4
I Adding appointments/tasks to other user's calendar Using Outlook 1
R Getting a colleagues appointments and calendar entries Using Outlook 1
N Outlook 2010 Archived Appointments Missing Using Outlook 5
Katrina Fox Missing appointments on calendar even though transferred from old pst Using Outlook 0
