Outlook with MDaemon Connectivity Issue
KPP-IT629
Here is to hoping for any kind of help for a user with unresponsive email that we have tried everything for. I am hoping someone sees something in this scenario that I have missed. Thanks for any help that can be provided.
User System Statistics
Msg count 15484
Disk Space 1475043
Using Microsoft Office Outlook 2010
User reported issues of Outlook not responding multiple times and only solution is task manager dirty shutdown.
Inbox >300 emails
Deleted >2500 emails
Contacts>5000
Calendar>1000
Server System Statistics
MDaemon Server (32-bit): v15.0.1
Registered / PRO / 250 users
SMTP/POP/IMAP server: v15.0.1
SecurityPlus for MDaemon:
AV overall system: v4.5.0
Outlook Connector for MDaemon:
Plugin: v3.0.0
Remote Administration Server:
HTTP server: v15.0.1
Changes, tests and rabbit hole
Computer
New Machine rebuilt Outlook fresh install of Office and Connecter
Physical Office
Moved to second RJ45 in same office
Moved to a third RJ45 outside of office to next office
Switches
Changed location of Switch port on same switch
Changed location of Switch port on different switch
Patch Panel
Changed location of Patch Panel connection to switch
Ping Tests
Pings to Mail Server within expectations
Pings to Domain Controller within expectations
Pings to Application Server and File Storage within expectations
Pings to Outside Address within expectations
Network Tests
No Lag in Application Server and File Storage requests
Email
Open large email <2MB and system will take up to 15 seconds to display
Close email and reopen instantaneous.
Close Outlook and Open same message will take up to 15 seconds to display
Once message is trying to open like the <2MB and system will take up to 15 seconds to display if you click anywhere inside Outlook –causes not responding error and crash.
This crash might need a full system reboot before it will open again.
Thought?
Great question yes the mail file is in location:
C:\Users\username\AppData\Local\Microsoft\Outlook.
Today we also ran SCANPST.exe on the file.
In the "other" outlook folder, in %appdata%\microsoft\outlook - delete the srs and outlprnt file. A corrupt SRS can cause crashes, usually on send and receive. Ah, and if send and receive is set belong 5 minutes, raise to at least 5 minutes, 8 to 10 min is better. A corrupt OTM (macros) file can cause outlook to crash, usually on start up but it depends on the macros too.
There are lot of issues and difficulties when you connect MDaemon with Outlook. If you are supposed to go with manual process then it’s going to very tough, rather than go with manual process I would suggest you to use third party MDaemon to PST Tool. Read this for more details.
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 3
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 25
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
P newly installed Office 365 includes OLD Outlook Using Outlook 6
R Outlook ribbon menu default? Using Outlook 7
