Delete selected text from incoming emails
I am not sure I understand that.
If I write this:
If Item.BodyFormat = olFormatPlain Then
b = lcase(Item.Body)
OldText = Replace(Item.body, "Text to Remove" & vbCrLf, "")
NewText = ""
Item.body = b
which is the code currently not working as it should, where would I add b = Item.body?
Correct - i had not considered this
Item.body = b
you definitely need to use
b = Item.Body
Item.body = b
which means the "text to remove." need to be the same case as it is in the message. Test it with just text, no ending space or new line: "Text to remove." not "Text to remove. " or "Text to remove. " & vbcrlf
Also... others ways to reference breaks is with chr(10), chr(13), or vbNewLine
oh, and don't forget to save changes. Item.save
Item.body = b
b = Item.Body
Item.body = b
This worked on my plain text message to remove extra lines at the top - i added it as 3rd replace in the plain text part.
OldText = vbNewLine & vbNewLine & "words in first line"
NewText = "words in first line"
b = Replace(b, OldText, NewText, , , vbTextCompare)
I find it hard to work out quite what changes you are advising me to make, so here is the full amended code - which produces exactly the same result - nothing changes!
b = Item.body
OldText = "Text to remove."
NewText = ""
Item.body = b
Item.Save
Set Item = Nothing
I am sure I am missing something very simple, but for the life of me I cannot see what.
The something simple was to close and restart Outlook!
Now it all seems to be working as it should. I shall keep an eye on it for the next few days to be sure.
Oh, yeah... you do often need to kick start the application start up macros for changes to take effect (especially after an error). I'm so used to doing it with every change, that i forget to mention it.
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
mikolajek Random message selected after hard delete Using Outlook 4
F Outlook 2021 Inbox delete icon missing Using Outlook 5
T Cannot delete a calendar Using Outlook 0
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
A Outlook 365 Delete entries in title field, address book Using Outlook 0
D Delete Outlook emails from MS server Using Outlook 17
G Automatically delete email when a condition is met Outlook VBA and Custom Forms 1
M Shift Delete doesn't delete email from server Using Outlook 3
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
O How to delete a forum post? Using Outlook 4
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
O Delete duplicate emails - subscription notifications Using Outlook 5
L Email Read and Delete Outlook VBA and Custom Forms 4
H Delete Calendar Entries in Using Outlook 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
