Macro for other actions - Outlook 2007
So, sorry to be a pain, but my problem seems to be happening much more frequently. So , how can I get the Microsoft Word 12.0 Object Library to show on my Outlook 2007. I do have the msword.olb file in the office 12 folder, but the icon looks like a blank page with it folded on the top right, so I'm not sure if that means it not enabled ?
Ok, I got it to work. I went thorugh those libraries numerous times, and couldn't find that Microsoft Word 12.0 Object Library, but I did eventully find it. Then I was getting an End Sub error, and discovered that when I copied your macro, I initially left off the last 4 or 5 lines. After I copied those last lines back into the macro, it worked. I haven't tested it on a live email yet, but I'm sure it'll be fine. And now that I have this working, I may ask for some other tweaks on it.
Thank you so much for your patience with me.
Ok, what instrructions just above End Sub would I need to get it to save ?
Thanks again,
The other receiver/sender is usually emailing from an Ipad, and does not change any other settings, just replies as is. Also MacAfee is not involved in these cases. Note that the large font and vertical formatting usually doesn't happen until maybe the 5th or 6th reply.
So can there be a macro to do the following on an opened email that is displaying some 120 pt. font size: Select All-Other Actions-Edit Message-Format Text- (select) 12 point font- Exit - Save ?
I’m used to recording macros in Excel, but don’t know how to do that in Outlook.
When receiving an email that has been replied to 4 or 5 times or more, often portions if the original message, or even some of the previous responses, are changed to very large fonts, usually 120 point.
Also, often some the previous responses are formatted with one word per line on the far right.
Like
this
it
makes
for
long
emails.
I have to manually Select all-Other Actions-Edit Message, change the Font to a reasonable size like 12, then exit to save. That will at least fix the large font problem.
How can I have a macro do that for me ?
I’d like to also have the vertical problem fixed too, but not sure if that is possible.
