Searches are not working properly
fritzmom
Outlook 2019 64-bit
Hello All
For the last while I've had problems with Outlook 2019 on my Windows 10 PC, searching.
If I'm in Calendar and search for something, always get the response, "no results" even though I know what I'm looking for is there.
If I'm in Contacts and search for someone I KNOW who is there, same thing, 'no results'.
And now I see that 'autocomplete' is gone bonky.
Are all these problems related?
I should add that everything is Indexed so that's not what's stopping Outlook from finding.
Thanks for your help
Barb
It can be a roadblock in your work when you want to search for something urgently, and your searches are not working properly. In such a case, try the steps below to resolve the issue:
  • Try to resolve the issue through the troubleshooter of Windows search.
  • Ascertain that details in the indexing are complete, and don't forget to include the data of Outlook in indexing.
  • Rebuild the catalog of searches and check if the search is working in the newly made catalog.
  • Ensure that the search service of Windows is enabled.
  • Use Control Panel to repair the office.
  • Try to reinstall the office to resolve the issue.
D.Moore Outlook desktop client suggested searches question Using Outlook 25
D.Moore Suggested Searches Using Outlook 2
U Outlook 2021 not showing contact cards in Searches Using Outlook 1
F Deleted calendar file - Outlook still searches for it Using Outlook 4
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
Commodore Automatic switch between working offline/online Using Outlook 4
Jennifer Murphy Spam filter not working Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
D Archive by receive date not working Using Outlook 2
cricket1001 Shade non-working days in calendar Using Outlook 0
