Forward incoming email with 4 embedded images in the body without original sender
This code works here.... not a good video but it shows the flashing that can't be avoided using word object model to copy.
ETA: this is a slightly better video - I'm closing the incoming message right after the copy. And I'm showing the sent copy.
It works with closing the incoming message after the copy, but without the display in the new message, it doesn't send the message.
Sub SendTransfer(Item As Outlook.MailItem)
Dim objMsg As MailItem
   ' Add reference to Word library
    ' in VBA Editor, Tools, References
    Dim objInsp As Inspector
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
If Not Item Is Nothing Then
   If Item.Class = olMail Then
   Item.Display
       Set objInsp = Item.GetInspector
   With objSel
      'use wholestory to copy the entire message body
        .WholeStory
        .Copy
Item.Close olDiscard
 Set objInsp = objMsg.GetInspector
 Set objSel = objDoc.Windows(1).Selection
With objMsg
    .Subject = "Transfers " & Item.Subject
    .Recipients.Add "diane@contrarytech.com"
     objSel.PasteAndFormat (wdFormatOriginalFormatting)
    .Display
    .Send
After adding the item.Close olDiscard, the compile error went away, and a blank email sent out. It didn't copy the content of the incoming email.
I will try your last code tomorrow.
The script runs great except the email subject didn't change to what I specify in the script. It goes out using the same subject from the incoming email. I also wonder will this script paste anything on my clipboard to the new email if I happen to have something copied at the time the incoming email arrives. Thank you so much!
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
