Crazy Exchange 2003 Scenario - Need Advice
  • Thread starter Corbin O'Reilly
  • Start date Views 1,732
C
Corbin O'Reilly
Hi everyone. Company1 has been around for 25 years. It currently has a
Windows 2003 Enterprise R2 domain running Exchange 2003 Enterprise Edition.
Company1 created a completely new company, Company2. Management doesn't want
Company1 and Company2 to be affiliated in any way as far as the outside
world is concerned. However on the inside Management wants the following:
1. Some employees with remain exclusively with Company1.
2. Some employees will be moved to Company2.
3. Some employees will be with both companies and need to be able to send
out e-mail from either company separately from @company1.com and
@company2.com.
4. They want to able to share/view calendars between Company1 and Company2.
By the way, Company1 and Company2 will be at the exact same physical
location and located on the same LAN.
OK, now it gets even crazier. At the same time Company1 has purchased
another company, Company3. Company3 is located three thousand miles away.
They have a Windows 2008 Domain and their e-mail server is hosted at a
outside hosting provider. A VPN connection through the Internet is setup
between Company1 and Company3 but the forests/domains are not trusted. Just
as with Company2 Management doesn't want Company3 to be affiliated in any
way as far as the outside world is concerned with Company1 or Company2 but
on the inside they want all three companies to be able to share/view
calendars and be able to send e-mail out of their respective domains,
@company1.com, @company2.com, and @company3.com. I told you this was crazy.
The big thing that Management wants to be able to do is share/view calendars
across all three companies. I really need some help with this one. I am not
sure if this can be done. I would appreciate any advice. Thanks for the
help.
L
Lanwench [MVP - Exchange]
> Edition. Company1 created a completely new company, Company2.
> Management doesn't want Company1 and Company2 to be affiliated in any
> way as far as the outside world is concerned. However on the inside
> Management wants the following: 1. Some employees with remain exclusively
> with Company1.
> send out e-mail from either company separately from @company1.com and
> @company2.com.
> Company2.
> away. They have a Windows 2008 Domain and their e-mail server is
> hosted at a outside hosting provider. A VPN connection through the
> Internet is setup between Company1 and Company3 but the
> forests/domains are not trusted. Just as with Company2 Management
> doesn't want Company3 to be affiliated in any way as far as the
> outside world is concerned with Company1 or Company2 but on the
> crazy.
> calendars across all three companies. I really need some help with
> this one. I am not sure if this can be done. I would appreciate any
> advice. Thanks for the help.
It's not difficult to host multiple public/Internet domain names in
Exchange - through the cunning use of recipient policies you could ensure
that anyone in Company1 gets user@company1.com for email, and same for
Company2 and Company3.
The issue is, does management care if savvy recipients can tell that
company1, company2, and company3 mail are hosted on the same Exchange server
(by looking in the headers, etc)? If not, this is not a big deal to set up.
The only problem you will run into is if they want a user to have email
addresses on both/all domains - you can't send mail from anything but the
default SMTP address without third party add-ins (ChooseFrom at
www.ivasoft.biz) or some very convoluted settings which I don't recommend
for a company this size.
Martin Blackstone [MVP]
"Lanwench [MVP - Exchange]"
<lanwench@heybuddy.donotsendme.unsolicitedmailatyahoo.com> wrote in message
> server (by looking in the headers, etc)? If not, this is not a big deal to
> set up.
This is the rub right here. Sometimes companies don't care, but sometimes
they do and that opens a whole new can of worms
C
Corbin O'Reilly
Thanks Lanwench and Martin for the quick replies. Unfortunately they do care
because they could get in trouble with some of their Partners if it
discovered that Company1, Company2, and Company3 are tied together in any
way. I should also throw it out there that they are willing to spend money
to get a proper solution. If that means setting up additional
forests/domains, purchasing servers, purchasing additional Internet
connections, etc., they will do that. Let me know what you think. I have
never come across a situation like this before. Is there any chance that the
new version of Exchange, Exchange 2010, and the new version of Outlook that
are going to be released at the end of this year will help in this scenario.
I may be able to convince them to hold off until those products come out if
they will help.
"Martin Blackstone [MVP]" <martinb@myrealbox.com> wrote in message
news:uw4NbpR5JHA.4296@TK2MSFTNGP06.phx.gbl...
> message
> > to set up.
O
Oliver Moazzezi [MVP]
Why not move Company1 and Company2 to the Cloud with Company3 email.
That way they all have their own AD, and have unity in email only.
Probably cheaper ultimately too.
Oliver
This was exactly what I was thinking. I would move them to the cloud and let
them rip.
It will almost certainly cost less than deploying more orgs.
"Oliver Moazzezi [MVP]" <o.moazzezino@spamfreenet.co.uk> wrote in message
news:uXd3qXS5JHA.972@TK2MSFTNGP06.phx.gbl...
> Oliver
L
> and let them rip.
Yep. But will they be able to collaborate/share between them?
> message news:uXd3qXS5JHA.972@TK2MSFTNGP06.phx.gbl...
>> Oliver
O
They could be provisioned as a single Cloud Customer so yes. Also if they
were setup and configured as 3 seperate Cloud customers if the Provider is
decent, then yes they should still be able too.
Oliver
C
Corbin O'Reilly
Setting up a single cloud with three sites that can share calendars
internally sounds very appealing. Any recommendations on providers that can
do something like this. I contacted RackSpace, www.rackspace.com, and they
said they couldn't do it. Thanks.
news:%234BHfLT5JHA.2456@TK2MSFTNGP02.phx.gbl...
> Oliver
C
Corbin O'Reilly
I just talked to Microsoft since they offer Hosted Exchange too and they
said it can't be done either. They have be in the same domain to view/share
calendars.
"Corbin O'Reilly" <corbinoreilly@bellsouth.net> wrote in message
news:8mUVl.6399$Xw4.5076@bignews7.bellsouth.net...
> can do something like this. I contacted RackSpace, www.rackspace.com, and
> they said they couldn't do it. Thanks.
> > is decent, then yes they should still be able too.
>> Oliver
Rich Matheisen [MVP]
On Thu, 4 Jun 2009 15:14:39 -0400, "Corbin O'Reilly"
> calendars.
Do you really mean "share" calendars, or did you mean that they should
be able to see each other's free/busy times? The two are very
different.
Rich Matheisen
C
Corbin O'Reilly
See each other's free/busy times. Basically act like one organization.
"Rich Matheisen [MVP]" <richnews@rmcons.com.NOSPAM.COM> wrote in message
news:pnqg251cm3l30q90ul9cth6nmei4empros@4ax.com...
> >view/share
> >calendars.
> different.
> -> Rich Matheisen
