Auto Remove [EXTERNAL] from subject - Issue with Macro
If the case for external never changes, this will work - use the correct case for External.
For Each Item In mail.Items
strSubject = Item.Subject
If InStr(1, strSubject, "[External]") Then
Item.Subject = Replace(strSubject, "[External] ", "")
Item.Save
I'll need to think on the best was to remove any case without affecting the rest of the subject.
Thanks! I'll try this.
I may have added it to the macro incorrectly, but after editing, it did not remove EXTERNAL. This is the code I used..
Sub RemoveExternalString()
Dim myolApp As Outlook.Application
Dim Item As Object
Set myolApp = CreateObject("Outlook.Application")
Set mail = myolApp.ActiveExplorer.CurrentFolder
' Remove from left or right
Dim iItemsUpdated As Integer
Dim lString As Integer
iItemsUpdated = 0
Item.Save
Next Item
MsgBox iItemsUpdated & " of " & mail.Items.Count & " Messages Updated"
Set myolApp = Nothing
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
H remove auto added signature macro Outlook VBA and Custom Forms 1
Hornblower409 Hyperlinks - Disable Auto Complete Using Outlook 0
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
C New pc, new outlook, is it possible to import auto-complete emailaddress Using Outlook 5
F Auto changing email subject line in bulk Using Outlook 2
