Send / Receive a particular group via macro or single keypress
Geldner
Outlook 2019 64-bit
I usually want to do a manual send/receive on a single account (I have five active in Outlook 2019 desktop). I don't see any easy way of doing this. I'm totally incompetent at VBA on my own but can cut & paste code. Any ideas?
Does it need to be vba? You can do it on the send/recieve group menu - add it to the Quick Access Toolbar for faster access.
TomHuckstep Remove Send/Receive All Folders (IMAP/POP) button from Outlook 365 Ribbon Using Outlook 1
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
Diane Poremsky Configuring a Manual Send and Receive in Outlook Using Outlook 0
M configure Onpremise exchange to send/receive emails internally and externally) Exchange Server Administration 0
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
J Send and Receive Button - only check default account? Using Outlook 1
S send/receive issues outlook 2013 Using Outlook 4
W OUTLOOK 2007 FREEZES. WILL NOT SEND NOR RECEIVE Using Outlook 1
Z Always Send from Default Account, depend of receive account Outlook VBA and Custom Forms 7
wisedave Office 365 Outlook - Emails send but don't receive Using Outlook 12
D Outlook 2010 hangs during message send/receive Using Outlook 2
Nesher Can send but not receive Using Outlook 1
David Trevose Hanging on Send Receive Using Outlook 2
mikecox "Send/Receive" goes missing Using Outlook 3
R Email Send & Receive Turned off but sends automatically anyway Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J why won't the automatic send/receive work Using Outlook 7
A Auto send-receive in Outlook not working Using Outlook 6
R send/receive no action Using Outlook 2
A yahoo mail doesn't send or receive reliably Using Outlook 1
E Strange Send/Receive count Using Outlook 3
Jennifer Murphy Why would I want to send/receive when offline? Using Outlook 0
S Send/Receive Progress is black??? Using Outlook 4
M Send receive Progress Box Using Outlook 4
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
A Send only, don't receive Using Outlook 1
K Send/Receive All Folders doesn't show Progress status Using Outlook 14
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
J Correct settings for send/receive groups w/Exchange Using Outlook 3
T Changed password now can't send/receive Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
J Send/receive getting stuck Using Outlook.com accounts in Outlook 1
X Send & receive takes SO LONG Using Outlook 1
P Send/Receive error in Outlook 2007 Using Outlook 2
W Send/Receive status bar Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
S Error code 0x8004102A Error With Send/Receive Using Outlook.com accounts in Outlook 2
S Connector Forces Outlook 2007 To Hang On Send/Receive Using Outlook.com accounts in Outlook 3
L Send/receive error (0X800CCC80) Using Outlook 2
B Send/Receive Status in Outlook 2010 Using Outlook 2
