Brick Walls.... Heads....
  • Thread starter Thread starter Conrad Rowlands
C
Conrad Rowlands
Hi Dmitry,
Not the first time we've conversed and I doubt the last... First Off I am using out-of-the-box VSTO, initially targetted at 2003 upwards but can draw a line at 2007 if need be....
I wondered if you had any idea on how to trap if the user changes their selection in a calendar. For instance I have a summarised view of the calendar showing the last month's events in a month view format, when I select a visible event within this view (not opening an inspector) and attempt to edit it I would like to know that I have made a new selection of an AppointmentItem. Do you know if this is possible? I do not want to use the ItemChanged event(which gets fired after the save anyway) as this can fire more than once. It seems a bit bizzare to me that we have a Selection Object but seemingly no way of indicating to the user that this object has changed...
Any help would be greatly appreciated.
Dmitry Streblechenko wrote:
You will get an Application.Inspectors.NewInspector event.
06-Jul-07
You can then set up an event sink on the Inspector.CurrentItem object and
trap its MailItem.Reply event.
Dmitry Streblechenko (MVP)
"DG" <DG> wrote in message
news:5B40AD6B-C303-44B2-B65D-314F6074686D@microsoft.com...
Previous Posts In This Thread:
On Friday, July 06, 2007 10:26 PM
D wrote:
MSG File - Trap Explorer Selection Change Event
---Dmitry, you may want to answer this one....
I am using the Explorer Selected Change Event for Outlook 2003 with my own
Reply All handler and I noticed if I save the e-mail as a standard MSG to my
C:\, I lose all Explorer functionality.
So, is there a way to utilize Explorer events when I open an MSG file from
the C:\? If not, what other ways are there to capture the Reply All on an
exported MSG file?
Thanks in advance,
DG
On Friday, July 06, 2007 11:46 PM
On Friday, January 08, 2010 12:45 PM
Conrad Rowlands wrote:
Heads.... Brick Walls
Hi Dmitry,
On Friday, January 08, 2010 12:46 PM
Hi Dmitry,
On Friday, January 08, 2010 12:47 PM
Hi Dmitry,
On Friday, January 08, 2010 12:48 PM
Hi Dmitry,
New RSS Feed Search Page
http://www.eggheadcafe.com/tutorial...6e-df15e06fb028/new-rss-feed-search-page.aspx
Try the Explorer.SelectionChange event.
<Conrad Rowlands> wrote in message
news:20101812494conrad.rowlands@dscallards.com...
> Hi Dmitry,
> Thanks
> 06-Jul-07
> my
> exported MSG file?
> Thanks in advance,
> DG
> Hi Dmitry,
> Thanks
> Hi Dmitry,
> Thanks
> Hi Dmitry,
> Thanks
> Hi Dmitry,
> Thanks
Apologies for the Multi Post
It kept asking me to log on once I had posted and as I was enrolling at the time I thought it had not posted my question!
08-Jan-10
Hi Dmitry,
ASP.NET 2.0 Virtual Earth Map Custom Server Control
http://www.eggheadcafe.com/tutorial...4a9-06059a6087a7/aspnet-20-virtual-earth.aspx
