Custom Contact card - need help creating one
Outlook 365 64 bit
I'm looking to get some assistance in creating a custom contact card in Outlook 365.
I would like to have the following:
- A drop-down menu, with pre-determined entries for the section highlighted 'Enquiry Avenue'
- The contact card to be universal (i.e. if I move the contact from one contact list to another, it does not revert to the default contact card, thus losing the additional info I am trying to capture in this custom contact card)
I've done what I can (as a novice) but need additional support in completing it.
Is anyone able to provide (idiot-proof) instruction on 'how to', or offer personal assistance in taking on the role - I'm not a developer by any means, and this is my first attempt at anything like this.
Thank you in advance.
Steve
Publish the form in the personal foms folder and the contact should use it no matter where the contact is.
For a drop down field, use combobox then in properties set the values -
Right click on the field, choose Properties. Create a new text field to hold the value and enter the values in the possible values field. Setting the initial value is optional.
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
oliv- Why custom form is different from original ipm.contact ? Outlook VBA and Custom Forms 4
Q Custom Contact Form - applied to existing contacts Outlook VBA and Custom Forms 5
F Custom contact form icon issue Using Outlook 1
C Outlook Custom Contact Form Attach Files in new notes fields Outlook VBA and Custom Forms 3
makinmyway Can I add a Map It Button to Custom Contact Form? How? Outlook VBA and Custom Forms 6
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
T Cannot view main tab of contact custom form BCM (Business Contact Manager) 0
J How to create a user defined dropdown list field for a custom contact form Using Outlook 3
P Creating custom contact forms Using Outlook 2
B Contact changes from Personal to Shared when opening custom form Using Outlook 0
H Custom Outlook Contact form Using Outlook 1
P OL2010 - custom form contact picture Using Outlook 0
J How Can I Change Owner of Custom Contact? Using Outlook 1
J Controlling/Changing owner of a Custom Contact item Using Outlook 0
V Custom UI Runtime Error in Business Contact Manager for Outlook (2013) BCM (Business Contact Manager) 6
C Custom Contact form - erase default value Using Outlook 0
M Custom Contact form queries (date control & contact/calender linking) Using Outlook 1
J Sharing Contact w/ a custom form Using Outlook 3
H How can you add a URL field in a Outlook Custom Contact form? Using Outlook 6
P migration issue from OL2003 to OL2010 with custom contact form Using Outlook 7
C Contact Custom Form - Category View Using Outlook 3
G how to set contact custom form as default contact form? Using Outlook 7
A Custom contact form replaced with the default OL form for another user Outlook VBA and Custom Forms 1
A New Contact entry (custom form) get saved in a public folder and doesn't appear in Outolook Contacts Outlook VBA and Custom Forms 3
J Checkboxes in Contact Custom Form Outlook VBA and Custom Forms 1
T Custom Contact Forms and User Properties Outlook VBA and Custom Forms 2
N Custom Contact Form in Outlook 2003 Outlook VBA and Custom Forms 1
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
Q More than one Notes section in custom contact forms Outlook VBA and Custom Forms 1
S Custom Contact Form Outlook VBA and Custom Forms 1
Z Custom contact form Outlook VBA and Custom Forms 7
