Recommendation for PST repair program
PhilBurton
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    Windows 10 Pro, 2H22
Outlook version:     Office 365
Email type or host:    IMAP
After the bad experience with the KernelAPPs program (see previous message), I'm gong to be more careful with this purchase. The only 2 options are Datanumen ($200) and Steller ($100 for lifetime license). If you have used one of these programs, what was your experience? Would you recommend the program to a friend?
I realize that there is a dramatic difference in price, but I'm seeking bulletproof reliability with a program that won't waste my time like KernellAPPs has.
I've used applications from all 3 - it's been a couple of years since I used the plain pst repair products though. Had good luck with all.
I would try Stellar first - use the trial to see if you like the interface before buying.
When you repair pst files, messages in corrupted folders will go into new folders. Messages that were deleted but the data file not compacted will be recovered too. You shouldn't have duplicates (unless you had duplicates before) - but the recovered pst file can look messay.
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
B How to get PST folder datetime? Outlook VBA and Custom Forms 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J Recover server side rules from OST/PST without access to the server Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
L Article on merging pst file Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
