How long it may take for 'Move all Replicas' from Exchange 03 to Exchange 10
smally01
Dear all,
Sorry for bothering you guys but I'm 'chicken' on doing that public folder migration/replication in between exchange 2003 to 2010.
Long story, can be a good example for what means by a 'failure migration on public folders'
I had a public folder with size of 80Gb, I messed up with just replicate all of it in one go - a public folder replication storm occured after I select the whole PF to replicate to the new server.
And in between I tried stopped that by
- delete inter-connection (routing group) in between servers
- delete quese manually (nearly impossible as we are talking about deleteing 10,000 (or even 100 times more) from the queue and ESM just hung in between process)
- remove the replica from the PF
- Finally find the 'stop replica' on ESM and command shell but the replication process just couldn't stopped.
Have to wait until the whole process done - 'weather the storm' <- someone say from the internet
And I had to re-do the PF replication folder by folder and now they all in good shape.
Story end and now this is my question on 'Move all Replicas'
Since the main goal is to discontinue the Exchange Server 2003 so I need do 'Move all Replicas' from exchange server 2003. Would that be the long process? Say I don't want to have another 'public folder replication storm' ...
Smally
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
I vba scrip to move emails based on long keywords list Outlook VBA and Custom Forms 0
Z alter the timeout for how long outlook looks for a content-server on an HTML-email? Using Outlook 5
Chris Grew How Long To Install BCM BCM (Business Contact Manager) 2
T Forwarded long email moves text to the right Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
G Opening messages takes too long Using Outlook 5
H Changing Organizer of event (for single to total calendar move; long way ) Exchange Server Administration 4
X Send & receive takes SO LONG Using Outlook 1
R Long delay for outgoing mail Using Outlook 2
A Eseutil File Dump fails in the path to the file is too long... Exchange Server Administration 2
Q Outlook 2007 Add-in Bug with with Exchange - Long explanation Outlook VBA and Custom Forms 2
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
T "Tabs from (eg) 5 May, 18 May and 17 June" in Favourites Using Outlook 3
N May 2017 Fix Didn't Fix? Using Outlook.com accounts in Outlook 6
Diane Poremsky Data loss may occur during public folder migration Using Outlook 0
S Outlook 2013 May 2015 Updates Using Outlook 0
adaminaus Quick question if i may Using Outlook 4
A Need May 2011 14.2 Outlook Hotmail Connector. Using Outlook.com accounts in Outlook 1
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 3
B Outlook 2019 Automatically move email after assigning category Using Outlook 4
M Move command Outlook VBA and Custom Forms 11
B Move emails from one account to another Outlook VBA and Custom Forms 2
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
