JFClark
- Outlook version
- Outlook 2013 32 bit
- Email Account
- Outlook.com (as MS Exchange)
Greetings SlipStick world.
While searching for a way to extract information from out Exchange Server, I came across this bit of code from this Site:
It works very well except it ignored the one address book I was trying to work with. After playing with the code and some strategic use of Debug.Print, I was able to determine that this code ignores any address list that does not equal olExchangeGlobalAddressList (Enum 0). The address book I tried to use is in fact olOutlookLdapAddressList (Enum 3)
I removed that IF...End If bit and the code did fine until it got the the LDAP address book and it threw an error. Apologies, I did not write it down and my notes are at work. If that detail is needed I can add it in when I get back to work. My question is WHY does the AddessListType HAVE to be a certain type and since it obviously matters, HOW do I get the same info from a LDAP address book?
Appreciate any assistance...
John
Sub DemoAE()
Dim colAL As Outlook.AddressLists
Dim oAL As Outlook.AddressList
Dim colAE As Outlook.AddressEntries
Dim oAE As Outlook.AddressEntry
Dim oExUser As Outlook.ExchangeUser
Set colAL = Application.Session.AddressLists
For Each oAL In colAL
'Address list is an Exchange Global Address List
If oAL.AddressListType = olExchangeGlobalAddressList Then
Set colAE = oAL.AddressEntries
For Each oAE In colAE
If oAE.AddressEntryUserType = _
olExchangeUserAddressEntry Then
Set oExUser = oAE.GetExchangeUser
Debug.Print (oExUser.JobTitle)
Debug.Print (oExUser.OfficeLocation)
Debug.Print (oExUser.BusinessTelephoneNumber)
John
