Outlook send problem
  • Thread starter amFtZXMgamFuc2Vu
  • Start date Views 2,516
amFtZXMgamFuc2Vu
When I uncheck 'send immediately when connected', (in the 'mail setup' tab)
emails will not send. Emails send fine when the box is checked. The 'include
this group in send/receive' box is checked.
V
VanguardLH
> tab) emails will not send.
And the "problem" is WHAT?
You unchecked (disabled) the option to send immediately. So Outlook is
probably doing what you specified by NOT sending immediately. That
means YOU have to perform a manual send.
You checked (enabled) the option and now Outlook sends immediately as
you configured it to.
> The 'include this group in send/receive' box is checked.
Did you also edit the group to make sure each account was enabled
within that group (and for both sending and receiving)?
You just walked through a bunch of configuration options of Outlook
without mentioning anything about them not performing as expected.
Your subject of "Outlook send problem" says nothing about WHAT is the
problem.
Tmlra2lC
Does it move the email you are trying to send to the outbox when the send
immediatly box is unchecked?
If so, pressing F9 or clicking Send/Receive should send the email.
FYI-
By unchecking the box you are telling it not to send until either:
1- You force a Send/Receive by pressing F9 or clicking Send/Receive
or
2- A scheduled automatic send/receive has occurred.
You set the time interval for the automatic send/receive setting in the same
screen as you set the 'include this group in send/receive'.
Hope this helps!
amFtZXMgamFuc2Vu
the email will not send when I hit send/receive.
> FYI-
> or
> Hope this helps!
Tmlra2lC
Check to see if your group is including the Outbox folder in send/receive.
You can check this setting in the same screen that you set your group to be
included in the send/receive. Try editing your group and check to see if your
outbox is included in the send/receive.
Best of luck!
> > FYI-
> > or
> > Hope this helps!
amFtZXMgamFuc2Vu
with the send automatically box unchecked and an email in the outbox, I hit
send/receive and it goes through the send/recieve process, and it says it is
completed with no errors, but the emial in the outbox is still there.
> problem.
Tmlra2lC
Although your group is included in the send/receive your group is comprised
of various folders. ie. Inbox, outbox etc.
If you edit your group you can check to see if the outbox is being included
in the send/receive process.
> > problem.
amFtZXMgamFuc2Vu
I've checked and the send box is checked. If I have it set on send
immediately, it works fine.
> > > problem.
amFtZXMgamFuc2Vu
I forgot to mention this is an imap account through gmail.
> > > problem.
Brian Tillman
"VanguardLH" <V@nguard.LH> wrote in message
news:gr3vrt$dml$1@news.motzarella.org...
Or wait until the send/receive interval occurs if one is defined.
zxylene
I know this is a few years late but I found this when looking for a solution. If you have Send immediately when connected unchecked. Make sure to uncheck schedule an automatic send /receive every minutes. with this checked I get email caught in my out box that will never send even with clicking F9 or send/receive. Odiously you want to make sure your email is pushed or is checking/receiving email regularly without this checked.
the email will not send when I hit send/receive. "NikkiB" wrote: > Does it move the email you are trying to send to the outbox when the send > immediatly box is unchecked? > If so, pressing F9 or clicking Send/Receive should send the email. > FYI- > By unchecking the box you are telling it not to send until either: > 1- You force a Send/Receive by pressing F9 or clicking Send/Receive > or > 2- A scheduled automatic send/receive has occurred. > > You set the time interval for the automatic send/receive setting in the same > screen as you set the 'include this group in send/receive'. > > Hope this helps! > > "james jansen" wrote: > > > When I uncheck 'send immediately when connected', (in the 'mail setup' tab) > > emails will not send. Emails send fine when the box is checked. The 'include > > this group in send/receive' box is checked.
This is with an exchange account? In Send and Receive groups > Edit, is the Exchange account included in the send and receive? Normally, it should not be since it syncs on a schedule, but the mail is probably getting stuck because its not in the group. I would not recommend including Exchange in an SR group, so your solution is probably the best option.
Or, if you don't like to use Send Immediately, set an 'after sending' rule to hold mail for up to 120 minutes.
Tip 149: Deferred Delivery - Outlook Tips - this may be the best of both worlds - you won't send immediately but can send on a schedule.
