Formatting Styles when Replying
Dmitry_N
I am really lost at trying various things to get a problem settled :(
The problem itself is that, when replying to a message, instead of using my Normal.dotm, Outlook picks up formatting styles from this original message, which I am replying to.
Example: my Normal style defines paragraph and line spacing. But this style is correctly embedded only when I create new messages.
However, when I reply to a message, Outlook picks up various ugly Normal styles from the messages, to which I reply, making, e.g., spacing between paragraphs or between lines in a paragraph huge.
Does anyone have an idea how to override this behavior?
Thanks so much in advance!
PS: Luckily, the font, which is used in the reply message, gets picked up from the "Stationary and Fonts" options, and these have nothing to do with formatting and styles, thank God!
Your font only gets picked up in replies because the stationery used by the sender doesn't define a specific font or font family.
I've not experienced Outlook using some goofy normal style setting - replies uses my preferred styles - although it might happen if the sender uses stationery.
What setting do you have yours set on / how did you change it? We changed the Normal syle to use 0 points after and use it. You can also change the style (as diane mentioned in a thread yesterday) - Format text tab, Change styles, (click in message body to enabled the options) - select para spacing. Make your changes (no spacing) and choose Set as default.
This page has some information about the problem - http://www.slipstick.com/problems/dblspace_html.htm
Please take a look at the pictures. Picture file names tell when Outlook behaves as expected and when it doesn't.
My Normal style is Calibri 11 pt, line spacing is "exactly: 12 pt".
New messages: always ok.
Replies: sometimes ok, sometimes not (you can see this on one of the pics).
You can see that the normal style gets picked up from the message, which I am replying to.
You can also see that the list of styles in each of the replies is different, so, I take it all styles that can be seen in replies are also picked up from these incoming messages.
Any solution to this ugly behavior?
PS: Sorry, it seems it's impossible here on this forum to post full-size images. Please take a look here:
https://picasaweb.google.com/lh/photo/Bccz-JlMYOiaKVZgb_fCTQ?feat=directlink
https://picasaweb.google.com/lh/photo/Bh3fXAriyAeiClrLy1BI3A?feat=directlink
https://picasaweb.google.com/lh/photo/4a9z32D7z2ystI-i6CP41w?feat=directlink
Correct, replies pick up the style of the original - the email includes its own style sheet. There are exceptions - most common if the sender doesn't use Outlook but it depends on what they do use. The only solution is to select all and change the line spacing (and anything else). Or use plain text.
Didn't mean to hit post so quickly... use the line spacing command to change the spacing of selected lines, the Change styles command to change the entire email. It's my (limited) experience that change styles will work on the entire document in most situtations, without selecting the text. This includes the header and signature blocks.
File, Options, Mail - near the bottom is an option for using CSS. You can try changing that setting.
Thanks for the reply.
I've found one useful button under "Change Styles" in the "Format Text Tab". It's called "Reset to Quick Styles From Template". Unfortunately, this button stops working if I add it either to Quick Access Toolbar or the Ribbon. Weird... Now I have to go a long way to reach this button.
Some commands are only usable under certain cirmumstances - if button is active in the Change styles menu, it should also be active when added to the QAT or ribbbon. (In my limited testing, its active when i hit reply to HTML messages.)
It's actually active, but hitting this button does nothing, unlike hitting the same button in its default location.
It worked for me, but i have only a few messages that either command made a difference.
I realize this is an old thread... So there's absolutely no way that when you reply to a message such that your own styles are used instead of the senders for what you type in your reply?
Using stationaries and configuring them to always use your fonts works most but not all the time.
Is there no way to configure Outlook to use a style that exists only on your computer when replying (instead of the Normal style) so that there's no way it's influenced by the sender?
No, there is no way to use your styles in replies - they should be available so you can select the test and apply your style, but they won't be used automatically. Outlook will use the same style as the sender used, if a style is specified. Sorry.
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
C View doesn't refresh (fields or formatting) Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
K Outlook tasks formatting Using Outlook 4
E Conditional formatting - when current account <> received account ? Using Outlook 3
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
S Conditional Formatting in calendar part of To-Do Bar Using Outlook 1
K Conditional Formatting based on Department of person received from? Outlook VBA and Custom Forms 4
L Email to task without changin formatting Outlook VBA and Custom Forms 16
C Change default colors for conditional formatting Using Outlook 2
Diane Poremsky Use Word Macro to Apply Formatting to Email Using Outlook 0
D Outlook 2007 Formatting Using Outlook 1
D telephone formatting Contacts Using Outlook 2
D Conditional formatting - font sizes Using Outlook 3
A Lync meeting in outlook lose HTML formatting Using Outlook 3
A Help creating macro for conditional formatting settings Using Outlook 8
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
Copwriter Paragraph formatting in blank messages/stationery Using Outlook 3
V Report stuck formatting page Using Outlook 1
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
J Formatting Contacts to Export for iPhone Using Outlook 0
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
A Using OR when organising with conditional formatting Using Outlook 1
G Outlook 2010 not formatting in-line comments Using Outlook 5
J Conditional Formatting Upon My Reply Using Outlook 1
Commodore Auto-formatting of certain phone numbers Using Outlook 2
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
E Email Formatting - Tabs Using Outlook 1
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
N lose conditional formatting when importing to Outlook 2010 Using Outlook 2
H Formatting of email conversation print outs - URGENT Using Outlook 1
K Problems with message formatting for individual user Using Outlook 1
M Auto-correct Contact fields' formatting? Using Outlook 7
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
K Outlook 2010 conditional formatting Using Outlook 21
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
W Formatting Outlook VBA and Custom Forms 1
H C# inserting word document with formatting into outlook message Outlook VBA and Custom Forms 1
