Distributing incoming mail among users
Sam
My organization receives a lot of mails, which I then have to forward to a
team responsible for attending to the query at the earliest. The logic to
follow is - 1st mail goes to user 1, 2nd to user 2 and so on, continuing in
cycle.
Currently I have a person to do this manually. I would like to know how this
can be automated using VBA, such that any new mail gets assigned
automatically.
This easy aproach might work - at least in theory: Put all of the users'
address in an array, so v(0) is the first recipient, v(1) the second, etc.
Use a variable on the module level to count the number of received emails in
the session. In the ItemAdd event of your inbox send the next email to
v(counter), then increase the counter by 1. If the counter is higher than
Ubound(v), set it back to 0.
This works only as long as Outlook is running, and it doesn't know for
whether user 1 for example is on vacation.
Best regards
Michael Bauer
Am Mon, 3 Aug 2009 20:47:01 -0700 schrieb Sam:
in
> cycle.
this
> automatically.
Mike,
First of all, thank you for responding to my query. The workflow suggested
by you sounds perfect to me. However, as I am only an intermediate level VBA
programmer with no past life in Outlook VBA - I am hoping to learn see some
code which I can use. Hopefully this will allow me to play with Outlook
objects / code, and I would be able to implement it for my organization.
Sam
> > Best regards
> Michael Bauer
> in
> > cycle.
> this
> > automatically.
Please start playing, the object browser helps you to learn the Outlook
object model: Press f2, switch from <All libraries> to Outlook, and see
what's available. For instance, find and select the ItemAdd event, the press
f1 for help.
Best regards
Michael Bauer
Am Tue, 4 Aug 2009 11:39:01 -0700 schrieb Sam:
> Mike,
VBA
some
> Thanks,
> Sam
etc.
in
>> > > Best regards
> > Michael Bauer
a
to
> > in
> >> cycle.
> > this
> >> automatically.
R copying a custom view from a public folder and distributing programatically Outlook VBA and Custom Forms 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
T Search for incoming e-mails for a specified time range Using Outlook 1
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
T Incoming Mail Changes Fonts Using Outlook 0
R VBA to manage incoming mail Outlook VBA and Custom Forms 2
I Capture incoming emails Outlook VBA and Custom Forms 1
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
P Use VBA to alert if new incoming email fits criteria Outlook VBA and Custom Forms 0
A Processing Incoming E-mails with Macros Using Outlook 0
D Delete selected text from incoming emails Outlook VBA and Custom Forms 25
Danny2015 how to change incoming mail conversationtopic successfully Outlook VBA and Custom Forms 6
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
A Incoming mail not downloading Using Outlook 2
G Rule starting a VB macro against incoming email Outlook VBA and Custom Forms 3
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
S The incoming task is not valid ((when users are accepting a Task) Using Outlook 5
Commodore Unified inbox or incoming messages view Using Outlook 27
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
A Alerts on incoming emails which are not responded since 1 day Using Outlook 1
J Cannot read incoming emails Using Outlook 2
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
J Incoming emails going to wrong sub-folder Using Outlook 4
F How to change all incoming fonts to black? Using Outlook 3
T Unset alerts from incoming email Using Outlook 11
S Outlook incoming mail & color blindness Using Outlook 2
