Auto processing of incoming mail
John
How can I check via code every incoming email, check if attachment of a
specific type (file extension) is present and if so save the attachment to a
folder?
Many Thanks
Regards
See various samples for the NewMailEx() event handler at
www.outlookcode.com.
"John" <info@nospam.infovis.co.uk> wrote in message
news:ORIKUdOJKHA.5984@TK2MSFTNGP05.phx.gbl...
> Hi
> a folder?
> Many Thanks
> Regards
J Auto processing of incoming mail Outlook VBA and Custom Forms 1
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
F Auto changing email subject line in bulk Using Outlook 2
