Could not retrieve IMessage: Interface not supported
Jeff
On some of my customers' machines, I'm receiving the following error
when my code accesses the SafeMailItem.Recipients property:
"Could not retrieve IMessage: Interface not supported"
I'm using Redemption 4.3 via late binding and registration-free COM.
Any ideas?
Jeff
Dmitry Streblechenko
Do you by any chnace have both Exchange Server and Outlook on the same
machine?
Dmitry Streblechenko (MVP)
"Jeff" <budajeff@gmail.com> wrote in message
news:df1c088a-79af-4330-ac88-e4d2ca931ff7@z19g2000vbz.googlegroups.com...
> Any ideas?
> Thanks,
> Jeff
Jeff
I presume not, but I will double check. Also, I believe that we are
using Redemption 4.7, not 4.3 as I wrote in my original post.
The customer ran the Repair feature of Outlook 2007's installer, and
that did not help. It seems that all of our Outlook COM and Redemption
code works, except the Recipients property.
We installed a previous version of our product that uses a 2006-era
version of Redemption, and the errors went away.
We were able to duplicate the error message on a test machine by
installing Outlook 2007, then installing Outlook 2003, and then un-
installing Outlook 2003. The error went away once we Repaired Outlook
2007.
> machine?
> OutlookSpy  - Outlook, CDO
> -"Jeff" <budaj...@gmail.com> wrote in message
> > Any ideas?
> > Thanks,
> > Jeff
Yes, that is a strong indication that you have 2 versions of MAPI
installed - MailItem.MAPIOBJECT marshaling from the outlook.exe address
space to your app is done by the version of MAPI loaded by Outlook, while it
gets unmarshalled by another version of MAPI loaded by Redemption in your
app address space.
news:bdce68a9-43fe-4389-8e4d-1ac70475acc1@r13g2000vbr.googlegroups.com...
2007.
> machine?
> > Any ideas?
> > Thanks,
> > Jeff
Jeff
> space to your app is done by the version of MAPI loaded by Outlook, whileit
> app address space.
> 2007.
> > machine?
> >news:df1c088a-79af-4330-ac88-e4d2ca931ff7@z19g2000vbz.googlegroups.com....
> > > "Could not retrieveIMessage: Interface not supported"
> > > Any ideas?
> > > Thanks,
> > > Jeff
We've also been able to duplicate the error message by setting the
default mail client to be Outlook Express instead of Outlook 2007. I
suspect that is the cause of the issue that our customer is
experiencing, as they do have Outlook Express set to be the default
mail client for reasons I won't get in to.
If you have any suggestions based on that information, let me know. I
wanted to post this in case it helps some one else in the future.
Jeff
Are
Jeff
I have a couple more findings that I want to share w/ everyone.
1)
Something in Redemption.dll changed between v3.4 and v4.5 that causes
my original issue. Simply by switching to different versions of my
custom Redemption dll, I was able to make the issue appear and
disappear.
2)
The solution to this issue is to add Redemption.dll (or your
customized Redemption dll name) to the following registry key:
Parent registry key name:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Messaging Subsystem
\MSMapiApps
New key Name:
Redemption.dll (or your customized Redemption dll name)
New key Data:
"Microsoft Outlook"
This will tell Windows to route all extended mapi calls coming from
any process that has Redeption.dll loaded into memory to use the
extended mapi routing information found at the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail\Microsoft Outlook
My original problem was caused by Redemption's extended mapi calls to
be routed to Outlook Express and not Outlook. Older version of
Redemption seems to be unaffected by this.
See the following for mapi call routing details:
Explicitly Mapping MAPI Calls to MAPI DLLs
http://msdn.microsoft.com/en-us/library/dd162405.aspx
Mapi32.dll Stub Registry Settings
http://msdn.microsoft.com/en-us/library/dd162409.aspx
Note that this issue only happens if Outlook 2007 is installed and
Outlook Express is set to be the default mail client. Also note that
I'm not registering (via regsvr32.exe) my custom Redemption dll, I'm
using registration free COM.
Does anyone know which installer is responsible for maintaining
\MSMapiApps ?
jb
Jeff
> 1)
> disappear.
> 2)
> \MSMapiApps
> New key Name:
> New key Data:
> "Microsoft Outlook"
> Explicitly Mapping MAPI Calls to MAPI DLLshttp://msdn.microsoft.com/en-us/library/dd162405.aspx
> Mapi32.dll Stub Registry Settingshttp://msdn.microsoft.com/en-us/library/dd162409.aspx
> \MSMapiApps ?
> Thanks,
> jb
I see that the issue i just described is listed on Dmitry's FAQ as
item number 7:
http://www.dimastr.com/redemption/faq.htm#7
Actually AFAIK MSMapiApps registry key handles only executables, not dlls.
news:6b282093-426f-4844-8a09-82eec93186d8@s16g2000vbp.googlegroups.com...
> 1)
> disappear.
> 2)
> \MSMapiApps
> New key Name:
> New key Data:
> "Microsoft Outlook"
> \MSMapiApps ?
> Thanks,
> jb
item number 7:
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
N How to retrieve user defined fields values to bcm form. Using Outlook 2
F Auto retrieve wont work Using Outlook 1
Chris Smith Outlook 2013 will not retrieve my IMAP mail Using Outlook 1
4 VBA - How to retrieve Meetings Saved but Not Sent? Using Outlook 0
K Outlook favorite folder disappear, how do I retrieve it back? Using Outlook 0
I Retrieve amount of calendar availability and attachments automatically Using Outlook 2
G Cannot retrieve emails past 2 weeks old Exchange Server Administration 1
R Went from outlook 2003 to 2010 - can't retrieve active for contacts Using Outlook 0
P Retrieve Meeting Response Text Associated with an Appointment Outlook VBA and Custom Forms 1
P CDO MAPI Session failing to retrieve user name but Getexchage user Outlook VBA and Custom Forms 2
S Retrieve the Mails with the attachment names changed Outlook VBA and Custom Forms 3
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
S The messaging interface has returned an unknown error Using Outlook 0
M Outllook 2000 - 2 Errors - The Information Service / The Messaging Interface Using Outlook 7
