How to write a macro to search inbox for certain numbers
  • Thread starter Thread starter jabri
jabri
Never written a macro in outlook before.
I'm sure this is pretty basic.
How would I write code to highlight everything in my inbox and search for
45678.
I would then take all of those emails and copy them to another folder and
then do another search for 45679 and do the same thing over and over with a
list of numbers. I would have to modify the list daily from an excel file.
Is this possible?
It's actually pretty simple, one line of code:
ActiveExplorer.Search("My search text",
Outlook.OlSearchScope.olSearchScopeCurrentFolder)
See the developer reference for more information:
Search Method [Outlook 2007 Developer Reference]:
http://msdn.microsoft.com/en-us/library/bb220302.aspx
Eric Legault - , MCDBA, MCTS (SharePoint programming, etc.)
> 45678.
> Is this possible?
So to be very step by step
just have my inbox open
Go to Tools/Macro/Macros
Macro name =test
Create
Sub test()
ActiveExplorer.Search("45678",
> > 45678.
> > Is this possible?
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
F Can I write a macro that triggers off an Outlook alert Outlook VBA and Custom Forms 1
P Possible to write a macro to print all attachments with specific . Outlook VBA and Custom Forms 1
S Macro to Write Rules Outlook VBA and Custom Forms 4
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
F VBA routine to write new sub routine in outlook Outlook VBA and Custom Forms 0
D How Would I Write This Filter? Using Outlook 3
M how do I write a plug in to send messages to a web app? Outlook VBA and Custom Forms 1
E RE: How do i write a letter to a business contact BCM (Business Contact Manager) 1
P Write a tool to generate a PST file with the same structure as old Outlook VBA and Custom Forms 1
B Write code for a button on New Form Outlook VBA and Custom Forms 1
S write and format a piece of text in the body using vba Outlook VBA and Custom Forms 7
S Write custom text in outlook infobar Outlook VBA and Custom Forms 1
A How to write into outlook status bar. Outlook VBA and Custom Forms 1
Q Outlook become non responsive if i write outlook item in bulk Outlook VBA and Custom Forms 20
V Outlook 2007: How to read/write Out-of-Office settings Outlook VBA and Custom Forms 3
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 1
M What is the recommendet way to read/write a user defined Field (Named Property) in the MailItem Obje Outlook VBA and Custom Forms 5
