VBA Macro for Archiving IMAP Emails to PST
registus
OS Version(s)
  1. iOS
Outlook 2021 64 bit
Outlook version:     Outlook 2019
Email type or host:    IMAP
Hi everyone,
I was trying to set up an automatic archiving system in Outlook using VBA. The goal was:
  • Capture all emails from a single IMAP mailbox.
  • Automatically copy them into a local PST file.
  • Preserve the same folder structure as the IMAP mailbox.
  • Avoid duplicates.
  • Handle new folders and subfolders dynamically.
  • The IMAP account will be used on two different computers, so each new email must be copied into the local PST on both computers, maintaining the same folder structure.
How to do it?
If everything is in the inbox, it's fairly easy to watch the inbox and copy. But if the messages are being moved to other folders, it can be a lot of folders to watch. The more you watch, the slower it works and could miss things - it would be better to use a COM add-in at that point, especially if you need it to create new folders added to IMAP - but you need visual studio to do that. (Plus know how to use it.)
Well, I'm completely new to Outlook macros and I'm not sure about add-ons.
COM add-ins are a lot more powerful, but not really for a beginner at VBA. (I haven't done an add-in is probably 20 years.)
I'm trying to think of a good - and fast - way to make a macro work. It could scan all folders and only copy messages since the last run but Outlook can't run macros automatically, so you'd need to do it manually. The last run time stamp would be stored in the registry. This would be the best way (i think, at the moment) if you are using folders.
If you only used inbox and sent, watching those folders would be the way to do it.
G VBA Macro Using Outlook 4
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
