VBA Macro To Save Emails
njunod
Outlook 365 32 bit
Hello - This is my first post on this forum so please forgive my ignorance - I'm trying to modify an old macro that I was given. The original macro would walk through all the emails in a user specified folder in their inbox and then ask the user where they wanted to save the emails (BrowseForFolder) and it would walk through all the folders and subfolders and save the emails in the same folder structure as was in Outlook to a network or hard drive with the name of the .msg file as YYYY-MM-DD_HH-MM-SS_subject.msg where the date and time was the mItem.ReceivedTime.
Now I want this macro to ask me for two dates to create a date range to apply to the mail items that are being saved. So for instance, let's say I have emails in folders and subfolders dating back to 2017. I want to run this macro and have it ask me for a date range so I can tell it to only save emails from 1/1/2017 to 12/31/2017. Once it's finished I then will run it again for emails from 1/1/2018 to 12/31/2018. So on and so forth.
The original code is attached, you can see my coding attempts commented out about 80 lines down or so:
So you want to do a search then save the search results?
While you can check the received date on each message, it will likely be faster to filter and process the results, especially if there are a lot of messages in the folder.
This shows how to use the slow method to do something with a message -
G VBA Macro Using Outlook 4
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
