hide outlook to system tray
  • Thread starter Thread starter mahmoud
mahmoud
I want to force users to open outlook 2003 at windoos startup
I found the following :
set shell = createobject("wscript.Shell")
shell.run "outlook.exe", 7, False '... SH_SHOWMINNOACTIVE=7 "should" work
wscript.Sleep 4000 '... may need tweaking 1000=1second
success = shell.appactivate("Outlook Today - Microsoft Outlook") '... window
must match first screen
if success then shell.sendkeys "% n" ' ... Minimize Alt Space Bar - n
i published by group polciy as login script it work just fine
but i need outlook to be hide to system tray how can i do that by login
script ?
any help
If you were to use the Outlook object model you'd set the
Application.Explorers.Item(1).WindowState = olMinimized. Or
ActiveExplorer.WindowState.
Using only Win32 API calls you have to post a message to that window's hWnd
to minimize.
"mahmoud" <mahmoud> wrote in message
news:43D04F88-CA1B-4F01-8B4A-19AA733422AB@microsoft.com...
> work
> window
> script ?
> any help
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
I Outlook 2010 - Remove or Hide Suggested Contact Folders Using Outlook 1
S Hide Folders in Outlook 2007 (IMAP) Using Outlook 5
H Outlook 2007 - hide completed tasks from Outlook Today -Solution Using Outlook 2
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
T How do I hide/unhide folders in outlook inbox? BCM (Business Contact Manager) 1
L Hide Selected Email Address from Address Book Using Outlook 5
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
D hide messege issue Using Outlook 1
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
S Hide Timestamp from deleyed message Using Outlook 4
K Hide Default Folders in PST Using Outlook 2
F Hide calendars from shared mailboxes Using Outlook 2
J Ho do I hide the week number on the Calendar Printing Assistant template Using Outlook 4
C How do I hide distribution list from global contacts for certain users? Exchange Server Administration 1
N Appointment Body on Custom Page 2- Hide Default Page Outlook VBA and Custom Forms 2
N How to hide pstStore Outlook VBA and Custom Forms 4
H Hide attachment... Outlook VBA and Custom Forms 3
S hide details of appointments in calendar Using Outlook 8
E Can I hide an explorer or make an explorer modal Outlook VBA and Custom Forms 2
C Re: Hide BCM toolbar BCM (Business Contact Manager) 1
S Volunteer request: opening invented MSG files in Outlook for Windows Using Outlook 0
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 3
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 6
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
B Sync Google Calendar with Outlook Using Outlook 5
