32 bit to 64 bit
matan
Outlook 2013 64 bit
Just bought the new ver. of Office 64 bit.
i tried to move all my old emails/folders by exporting the .pst from my old 2003 ver. (32 bit) to the new ver. (64 bit)
i keep getting the :
"Cannot display the folder. Microsoft Outlook cannot access the specified folder location. The server is not available. Contact your administrator if this condition persists."
is it because the 32/64 bit differnt ver.?
is there any way to convert the 32 .pst to 64?
thanks
No, the bitness won't matter, especially with a pst file. Something else is wrong. Did you make a new profile? What type of email account is configured in Outlook?
both configured emails are pop3 (is that what you mean by configured?).
i tried to import the .pst before i even started the accounts settings (several accounts), but the same error occured when i tried to import it after the accoounts settings.
**the .pst is ~5gb.
**it contain several folders.
**i did not set all the emails accounts before i tried to import the .pst.
**i scaned and fixed the file.
Yes. In some cases when upgrading versions, Outlook thinks you have an exchange account and can return a similar server error message.
As long as there is a post file, it doesn't matter if the accounts are set up. And as long as the pst is not the old Outlook97-2002 format that is limited to 2GB, you don't need to import - just open the pst in the new profile and set it as the delivery location for the account(s).
Did you set a password on the pst? That error also results when a pst is passworded but you cancel the dialog. Outlook has been known to think there is a password when one was not set - try one of the password utilities here and see if it 'sees' a password. (I use pstpassword because it was the first free one, but any should work fine.)
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
Phillip Bit.ly emails Using Outlook 1
A Office 2016, 32 vs 64 bit Using Outlook 1
S Outlook 2010 32-bit Shared folders Using Outlook 1
Commodore Office 2013 64-bit over 2010 32-bit Using Outlook 11
A Yearly Calendar in Outlook 2010 64 bit. Using Outlook 1
E Need a bit of education on how Outlook works please Using Outlook 3
R 2013 64-bit Due times (deadlines) on tasks: how to set Using Outlook 1
D Particular Facebook "Hyperlink" Issue In Office 2010 Outlook (32 bit) Using Outlook 5
K CPA - Office 2010 - 64 bit Questions Using Outlook 1
Commodore 64-bit or 32-bit on 64-bit Win7? Using Outlook 0
W Calendar Printing with Outlook 2010 (64 bit) Using Outlook 1
D A little bit of help with headers please? Exchange Server Administration 1
J Junk email filer stopped working in Outlook 2010 (32 bit) on a 64-bit Win 7 PC Using Outlook 12
I Send Secure Email Through Microsoft Outlook 2007 and 2010 (32 bit) Using Outlook 0
C MAPI to access a 64 bit Outlook from a 32 bit application; or access via ODBC Using Outlook 0
K Outlook 32-bit Connector and Outlook not displaying the folders Using Outlook.com accounts in Outlook 10
J 32-bit app using 64-bit Outlook COM objects? Outlook VBA and Custom Forms 3
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
S Archive bit in email messages? Outlook VBA and Custom Forms 3
