Particular Facebook "Hyperlink" Issue In Office 2010 Outlook (32 bit)
DKW
I'm using Office 2010 Outlook (32 bit) on my Dell XPS 400 (no Exchange Server Account),with Windows XP SP3, and always download and install the suggested Microsoft updates.
For the past 2 months now, whenever I get a Facebook Status update email from a friend, the embedded Hyperlink WILL WORK when clicking on the the "View Post" option, or by clicking directly on a featured photo;but clicking on the "Like Comment" & Share" hyperlink option below the posts, NO LONGER redirects properly, and comes up with a "404 page not Found" error on Facebook.
This link below, is the only one that is shown whenever I try clicking on one of the 3 options for ANY Facebook email that I receive that is similar:
https://www.facebook.com/sig_t?sig=AVK_Lzl5yS-YVQQ8
This happens whether I choose ie8, or Firefox, with the proper "Protocol"/"Default" assignments under "Add Remove", File Types under "Folder Options" , and with ie8 and Firefox's individual "Options.
And with the exception of doing a "Redirect" edit using Microsoft Office 2010 Visual Studio Pro, I've tried EVERY other suggested online fix for "Outlook 2010 Hyperlink" issues, including "Regedit" tweaks, deleting the "OutlookSecureTempFolder" in the registry and creating a default one, and all of the "Fixits" I found that address this issue.
But as I wrote it is solely the "Like", "Comment" and "Share" hyperlink options underneath these FB status update emails that have this problem, the other hyperlink options within these emails work fine.
I really liked having this option, because they actually worked, unlike the usual "faux" hyperlinks where you have to go to the redirected site to click on the site's links directly.
I've googled this particular issue extensively, and have NOT seen it posted (even on FB forums), so it definitely looks to be a new one, most likely due to a either a Security update, or possibly another Facebook Admin change, but they aren't talking.
I downloaded and configured the extensive set of Microsoft Office GPO Administrative Template options (under "Machine" and "User") to see if that would help, as well as signing up for "Outlook Social Connector", but NO DICE .
And before anyone suggests the "FBLook" Plugin, their site currently has this notice posted, as of 10-9-13:
"Facebook has made several changes, which made FBLook incompatible. We have temporarily taken FBLook offline while we fix them. Thank you for your patience and support."
I'm no "Techie", and trying to use Visual Studio would not only be out of my league, but possibly even dangerous should I mess up my registry or something. So I must ask for help, ANY of which would be MUCH appreciated. Thanks.
-DKW
DKW
Okay. FYI, I just tried disabling Facebook's "Secure" browsing to see if that was the issue, but no.
DKW
So, were you able to confirm that it was a Facebook "API" change causing this particular problem?
I should add, that I get the same error when I click on one of the 3 options in the emails via my Mobile device's basic Outlook service, and app, as well....
No, my messages from facebook are fine and i can't repro this problem. If its also happening on your mobile device, the mail is hitting the server messed up, it's not outlook doing it. Security software (antivirus or antispam) on the server may be at fault.
DKW
Well,
After re-installing Windows XP MCE on a new Seagate Barracuda Drive for my Dell XPS 400, and contacting Earthlink support last night, with the tech doing a complete round of "remote" troubleshooting with different Browsers, etc. via my email account, it looks to be coming from Facebook's end, as the tech got the same error with that particular "404" link that I've been getting.
But there's NO way I'm going to email Facebook Help and hold my breath waiting for an answer; so, I'll simply have to give up...
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
Geldner Send / Receive a particular group via macro or single keypress Using Outlook 1
V extract users of a particular department Outlook VBA and Custom Forms 1
RBLampert Outlook downloads error out if one particular account is the first to download Using Outlook 0
E Can't Set a Particular Account as an Outlook Data File Using Outlook 1
G How to export a particular line in the body of the mail to excel? Outlook VBA and Custom Forms 1
P How to set the time for particular funtion? Outlook VBA and Custom Forms 1
I How to extract email addresses from TO or CC line of a particular email Outlook VBA and Custom Forms 2
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
Rupert Dragwater Facebook notifications marked as Norton Antispam Using Outlook 6
iwshim Outlook Social Connector for Facebook - updates? work arounds? Using Outlook 1
Commodore First LinkedIn, now Facebook... Using Outlook 3
D Text Of Facebook Status Updates & Posted Photos NOT Showing In Emails Using Outlook 3
F Outlook 2013 and Facebook Using Outlook 2
Commodore Difference between Facebook entries in browser vs. people pane Using Outlook 2
Commodore Outlook 2007 stops fetching Facebook updates Using Outlook 5
C stop facebook? Using Outlook 16
Diane Poremsky Facebook and Live Providers for Social Connector Using Outlook 2
V Embedding hyperlink into Word document Using Outlook 2
L Ignore hyperlink from being flagged as false pattern Outlook VBA and Custom Forms 3
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
M How to view the URL for a hyperlink? Using Outlook 1
A Add Hyperlink to Task Outlook VBA and Custom Forms 11
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
V Using custom field data in mail body + mailto hyperlink Outlook VBA and Custom Forms 7
C Hyperlink to an Outlook search Using Outlook 1
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
E Create a URL hyperlink in an Outlook custom form? Outlook VBA and Custom Forms 2
J Macro generating email using default signature and hyperlink Outlook VBA and Custom Forms 5
Witzker HYPERLINK "mailto:test@test.com" in form body Using Outlook 21
Hudas Hyperlink Saved Outlook Email to MS Access Table Using Outlook 4
S email body without "HYPERLINK" ( vba ) Using Outlook 6
M How to create a hyperlink to to an organizational form Using Outlook 5
J Hyperlink VBA Using Outlook 1
P Can't add a custom hyperlink to toolbar in OL 2010 Using Outlook 1
T Desable Hyperlink on email Using Outlook 3
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
