Auto click a hyperlink
malemodel_75
I am very new to vba/macros etc.
My problem: I receive many emails daily to which i need to click on a hyperlink within a time limit to verify receipt of the email. It is very tedious task to having to be on 'standby' to do this mundane task.
I am trying to setup a macro where when an email is received it automatically clicks on the link for me. Is this possible?
Thanks in advance,.
Johnb
"malemodel_75" <malemodel_75[at]yahoo[dot]com> wrote in message
news:u5TbKIdpKHA.1556@TK2MSFTNGP05.phx.gbl...
> Hi,
> tedious task to having to be on 'standby' to do this mundane task. I am
> Thanks in advance,.
I use the following code everyday to manipulate a web page. It is run as a
vbs file, but I expect the code will be v. similar in outlook VBA:
Yes it is,
strUrl = "http://www.example.com" ' obviously you will have to parse the
appropriate address out of your message body
set xmlhttp = CreateObject("MSXML2.ServerXMLHTTP")
xmlhttp.open "GET", strurl, false
xmlhttp.send ""
strBody = xmlhttp.responseText
set xmlhttp = nothing
John
http://www.LbeHelpdesk.com - Help Desk software priced to suit all
businesses
http://www.room-booking-software.com - Schedule rooms & equipment bookings
for your meeting/class over the web.
http://www.lbetoolbox.com - Remove Duplicates from MS Outlook
malemodel_75
Hi John,
Thank you for your reply. However, I am a very basic user and that code was all jargon to me. I am not sure what to change, how to change it and where to get the data.
Looking further into the email messages, the link that I need to click is automatically generated with a unique order reference number. So I guess its not linked to i.e. www.example.com more like www.example.com/order123456
Could you guide me via a step by step proceedure?
Thanks a million,
Dan.
M auto click hyperlink?! Outlook VBA and Custom Forms 1
