Run a script rule to auto 'send again' on undeliverable emails?
KamCastle
Outlook 2016 64 bit
Hi there -
I was looking for a way to automatically resend the original message that populates from the "send again" button in the undeliverable emails that I receive frequently due to the workday that we need to resend. Please let me know of any way I can achieve this.
This macro might work for bounces- I don't have any bounces handy to test it on - will need to make some. It can be automated.
L Run script rule not exectued for first few mails Outlook VBA and Custom Forms 2
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
E run script fails suddenly Using Outlook 3
L Run A Script not listed in rules wizard Outlook VBA and Custom Forms 12
V Outlook macros no longer run until VB editor is opened Outlook VBA and Custom Forms 0
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
