Synchronization and taking forever to send
Chrisokia
Outlook 2016 64 bit
Operating system::    Win 11 pro
Outlook version:     Outlook 365
Email type or host:    imap
I just got a new computer and put outlook 365 on it. I am using ONE account through migadu.com using imap.
It is forever syncing and will not send email due to constantly syncing.
This account has been used for nothing except setting up the credentials and downloading all emails. The file is pretty big...40 GB
There are NO rules. There is only 1 non-automatically added folder and that's a 'Saved Emails' folder.
Even ending the S/R and immediately going to the outbox and trying to 'send all' does nothing but 'processing'
Please help. Folder count is turned off in send/receive.
Hi Chrisokia, please try the following:
Click on Send/Receive > Send/Receive Groups > Define Send/Receive Groups
- click on Edit, choose your Account
- uncheck “Get folder unread count for subscribed folders”
- enable “Use the custom behavior defined below”
Folder Options:
- only check mark the Inbox folder
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 0
M Synchronization and backup of Outlook from local to server. Using Outlook 11
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
R Outlook 2010 Contact Synchronization - Outlook to Outlook.com Using Outlook.com accounts in Outlook 1
Paul Van Cotthem Is calendar synchronization between Office 2013 and Outlook.com capped by spam or bandwidth limits? Using Outlook.com accounts in Outlook 12
A Synchronization of IMAP folders Using Outlook 0
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J Synchronization of some deletions failed [0-130] Exchange Server Administration 6
M Synchronization of some deletions failed [0-130] Using Outlook 3
S Improving synchronization of Outlook with ... everything else Using Outlook 1
A Synchronization Error of contacts and calender using Outlook connector Using Outlook.com accounts in Outlook 12
D BCM and remote synchronization BCM (Business Contact Manager) 1
T Synchronization error event Outlook VBA and Custom Forms 4
N Cut and Paste Taking 25 seconds Using Outlook 0
J Emails stay in Outbox forever once addin is loaded Outlook VBA and Custom Forms 3
