[duplicates duplicates duplicates] please help
vze2mp9g
Outlook 2013 32 bit
This is an odd thing I ran into when I went to use my contacts. When I go to choose someone from my contacts, I have duplicate contact lists which are EMPTY. I knows this sounds odd, so I'm going to give you a screen shot of what I mean:
How can I DELETE these empty contact entries in my address book. I have no idea how this happened. My guess is that it could have happened when I used Apple's iCloud fro Windows.
Thank You :)
Go to the Folder list (Ctrl+6) - how many contacts folders do you see? I'm expecting 5 sources (1 contacts, plus linkedin, iCloud, accounts, business)
Go to File, Account Settings, Address book tab. Double click on outlook address book. How many are listed? I'm expecting you'll see your long list - Remove all of the ones labeled contacts. Close the dialog, go back to the contacts folders (either folder list or People pane) and right click on the Contacts folder, choose Properties then Outlook Address Book and enable it as an address book.
vze2mp9g
Outlook 2013 32 bit
Yes, I believe that there are 6 EMPTY contact folders. This is the complete list:
Verizon On Line - Empty
Accounts - Verizon On Line - Empty
Business - Verizon On Line - Empty
Contacts - Verizon On Line - Empty
iCloud - Verizon On Line - This contains all my contacts
LinkedIn - Verizon On Line - This contains all my contacts from LinkedIn (This was something I didn't expect to see!)
Now, should my first one (Verizon On Line) have anything in it, what about the next two (Accounts and Business)?
When I go to the File, Account Settings, Address book tab and double click on the address book, I have several address books, and they are:
Accounts: Business Contact Manager
Business Contacts: Business Contact Manger
Contacts: AOL Mail
Contacts: Archives
Contacts: Archives
Contacts: Google Mail
Contacts: Hot Mail
Contacts: iCloud
Contacts: iCloud
Contacts: Verizon On Line
Contacts: Yahoo Mail
LinkedIn: Verizon On Line
Can you guess which one(s) I should delete? See below for the screen shots:
6-5-2013 9-41-00 PM-1.jpg 6-5-2013 9-42-03 PM-2.jpg 6-5-2013 9-42-31 PM-3.jpg
This looks like a mess? I know! :eek:
Thank you, you've been a BIG help!
You can remove all from that list then go into the Contacts pane in Outlook, right click on the contacts folders, choose properties and enable as address books.
I'm guessing the empties belong to these -
Contacts: AOL Mail
Contacts: Archives
Contacts: Archives
Accounts and Business Contacts are from BCM.
vze2mp9g
Outlook 2013 32 bit
Contacts: AOL Mail
Contacts: Archives
Contacts: Archives
Yes, you are correct on all of them, but there are still more. I'm enclosing screen shots of what are the empty contacts and which ones are full.
I believe that pictures can better explain what is going on. I hope that you could find a way to correct (if possible) the minor problems. Lastly, is there a way to make just one of the contacts listed as my default, so when I go to send a message, Outlook won't take the first one on the list, which is my Verizon On Line.
Thank You.
David
Ok. Now i understand. You have a bunch of accounts/data files and the data files each have a contacts folder. You can't delete them from the navigation pane - i usually make a group and drag the unused ones into it.
In the address book, I would delete all from the list then go back into outlook and enable them as address book. Remove them from the Address book in this screenshot: https://forums.slipstick.com/attachment.php?attachmentid=692&d=1370730585&thumb=1 After you remove all of the lists from the address book, right click on the folders with contacts in them and choose Properties, Outlook Address Book and enable as address books so they show up when you click To.
I'm not sure why you have multiple linkedin and iCloud folders, you should only have one of each. The 'this computer only' folder could be removed by deleting the imap data file and letting outlook rebuild it - provided it is not set as default. Just make sure there are no appointments or tasks in there either.
vze2mp9g
Outlook 2013 32 bit
Okay, this was easy to do. I've done this.
Do you mean DELETE THEM ALL! This sounds a little unsafe. See below of what I did so fare.
How do you set an Address Book as the "Default"?
Do you mean delete ALL these contacts?
I think I'm almost there! So you want me to delete all the Contacts above and how do I get Outlook 2013 to "Rebuild" the contacts?
Thank You.
oh, probably not. :) I've been mostly offline since Thursday when my webserver went down and the host was slow as bringing it up. I ended up moving it to a new site and it took longer than expected to get it set up. After 40 hours they got the server back... as soon as i make a new backup, the account will be canceled.
Delete the list in the last dialog - click the remove button. There isn't a default contacts (other than what is in your default data file) but you can set which address book should be shown first. That is set in Address book's tools, options (I think).
vze2mp9g
Outlook 2013 32 bit
Okay, I did something different. That's why I've been away for a while, I decided to back up all my personal data (including all the PST OST and signature files) and copied my Users/David/ directory completely. Then I reinstalled Windows 7 SP1 and Office 2013. Then I put the PST file back first, everything good, except all my contacts were gone! But when I go to send an e-mail to someone who was in my contacts, it will automatically put their full e-mail address in, like if I did have my contacts still there. Now, is there a way for me to get by my contacts? If so how. Remember, I have a backup of everything in my users directory, so If I didn't copy the right file, I can always get it back from the backup.
I did go into my account settings and attempted to "Repair" it, but it didn't do too much. All I know is that the original PST file has everything in it except the signature(s). It kept all my rules, and filters, and everything except my contacts. PLEASE, tell me that I can get them back.
Lastly, I just got off line talking to my IP (Verizon), and I wanted to "Sync" my Outlook 2013 calendar with my online calendar similar to the way with the other online providers (Hotmail, Gmail, AOL, Yahoo, and Apple (iCloud)), and they told me if Outlook can support it, I should be able to do it with Verizon. Do you have any insight on this? I don't really think you would, but they had no idea, or at least that's the way it came across to me.
BTW, if I don't hear from you, I wish you and everyone on this Forum and safe and happy Forth of July! :cool:
larry
So the contacts folder in the pst is empty? What other account types were in your profile?
Do you know who services Verizon's email? I know they used to use MSN but I don't know if they still do.
vze2mp9g
Outlook 2013 32 bit
Yes, the contacts folder in the PST is empty, but, like I mentioned, when I go to type the first letter of a person who was in my contacts folder, Outlook will start to suggest people who were in my contacts folder.
As far as who services Verizon's email, your guess is a good as mine. I would go with what you know, and say it's still MSN. IMHO, I don't even think that Verizon's first line of technical support people would even know that. The person I was in live chat didn't know to much about Outlook and how to integrate/sync their contacts & calendar with Outlook 2013. I really appreciate you taking the time to reply to my posting.
Thank You. :)
Forum Admin
The answer really requires knowing who services the account - if the contacts and calendar are online there are only 2 ways to sync with outlook. EAS/Outlook Connector or Exchange Server. Any other mail server does not support sync - you need to export as a CSV and import into Outlook.
Can you post a screenshot of what you see when you log into the account's web access? What the interface looks like can give us a clue.
vze2mp9g
Outlook 2013 32 bit
Okay, I'll try to do an online chat again and hopefully, someone will know what I am talking about, but it will sound like I'm talking in Latin to them. As far as sync with outlook, what is EAS/Outlook Connector? What I really would like to do is somehow rebuild my contacts from my PST file because as I type the first letter of the contact (who was in my contacts) it gives me suggestions of who I could mean. Is the contacts in the PST file, if not can you tell me where the contacts are because I made an exact copy of my complete users directory, including hidden and System directories/files. I'm just concerned in getting back my contacts from my PST file because I had 137 contacts with detailed information.
Okay, I'll post a screenshot of the account's (Verizon's) web site. There is no way for me to EXPORT, but I can IMPORT. Even the customer support/tech support person told me that there isn't an EXPORT function. He did say that if Outlook supports syncing of contacts & calendars, then Verizon has no problem doing it. Also, he gave me a different Outgoing Port (SMPT) and to use 465 and Use the following type of encrypted connections SSL.
I will, hopefully, get back to you tomorrow.
Thank You.
The port is just so outgoing mail gets sent - some networks block the use of 25 and 465 gets past the block.
The old default location of pst files was under the local appdata path - in Windows 7/8/vista, that is C:\Users\username\AppData\Local\Microsoft\Outlook
It is a hidden file.
It sounds like the autocomplete cache is present but something happened to the contacts.
Outlook Connector is an addin Microsoft released that allows you to sync with Hotmail accounts (now Outlook.com). Outlook 2013 has support for Hotmail built in - using Exchange Active Sync (EAS).
Good luck with Verizon support. :)
vze2mp9g
Outlook 2013 32 bit
I think you mistook me, the .OST files are in the C:\Users\UseName\AppData\Local\Microsoft\Outlook directory and the .PST files are in the E:\Users\UserName\Documents\Outlook Files directory with Windows vista/7/8, at least that's where they are in my system and I'm using Win7 SP1 Ultimate [32-bit].
Am I correct in saying the contacts & calendar is IN the PST file and not separate in another folder?
As far as Outlook Connector, I have Outlook 2013, and do I need to get an addon to have support for Outlook/Hotmail, or do I need to set it up differently to use Exchange Active Sync?
Thanks for the support with Verizon, but all they gave me was the same old answer which you can find on line, setting it up as a POP3 account. I've included the screen shots that someone else requested of my settings on Verizon.com:
see my next posting for more screen shots of Verizon On Line
vze2mp9g
Outlook 2013 32 bit
More screen shots of my Verizon On Line settings :
and my next posting for the final screen shot of my Verizon On Line Settings.
vze2mp9g
Outlook 2013 32 bit
This is my last screen shot for my Verizon On Line e-mail account:
One last thing for Diane, is there a way to get my contacts back from my PST file for Verizon?
Thank You.
David
I'm not sure what I was thinking. :) The paths you see are the new paths, as of outlook 2010.
Calendar and contacts are stored in the data files with email - in Outlook 2013 this can be in the Outlook.com data file, an IMAP data file, or a local pst file. If they are in an outlook.com data file, they will sync to the server. If they are in a POP# or IMAP data file, you won't sync. (I do not recommend using an IMAP folder because they could get lost too easily.)
The "junk" needed to sync outlook with Outlook 2013 is built in, you do not need anything extra.
It does not look like Verizon-branded Hotmail- it looks like some flavor of linux. That means you are limited to POP3 and need to export the contacts (and calendar) as CSV file to get them into Outlook.
I assume this is the instructions you use: http://www22.verizon.com/support/re...et/email/setup+and+use/questionsone/86782.htm
