redemption reference
seeker
I asked about the outlook permission box that appears when i use sendobject
in my access code. An access newsgroup said that I need to learn about the
redemption reference from you guys. So what do i need to do to stop this
permission box everytime my vba code sends an email. The email is being sent
in house so I am not concerned about a security breath.
K
Ken Slovak - [MVP - Outlook]
SendObject uses Simple MAPI, which is subject to the security restrictions.
For information about your options see
http://www.outlookcode.com/article.aspx?id=52
"seeker" <seeker> wrote in message
news:07A9836D-781E-473A-946B-E1D8001E31E7@microsoft.com...
> the
> sent
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Y Redemption MessageItem SaveAs problem Outlook VBA and Custom Forms 8
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
Q REDEMPTION HANGING during LOGON Outlook VBA and Custom Forms 2
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
K How to reference the selected folder Outlook VBA and Custom Forms 1
N VBA Outlook reference to Excel and assigning category Outlook VBA and Custom Forms 13
U Reference Text for VBA for outlook Outlook VBA and Custom Forms 1
M Is there a reference for the valid XML tags and their options? Using Outlook 3
N Providing a reference to incoming mail in outlook 2007 BCM (Business Contact Manager) 2
C Shared Calendar Recipient Reference Outlook VBA and Custom Forms 1
