REDEMPTION HANGING during LOGON
Q
QVZJUw
I have two applications developed in Visual Basic. Both the applications use
REDEMPTION to communicate with EXCHANGE SERVER. The main application just
hangs when the following command is executed, whereas the same command is
executed perfectly fine with the second application.
Call oRDOSession.LogonExchangeMailbox(ExchangeId, ExchangeServer)
Can anyone suggest or help, to resolve the problem.
Thanks in advance for the help.
Dmitry Streblechenko
Are you sure it really hangs rather than return error that your code does
not expect?
What is different between these two apps? Are they regular UI apps?
Dmitry Streblechenko (MVP)
"AVIS" <AVIS> wrote in message
news:1BB7A5AF-B36A-4B2E-AB20-420061CF61A9@microsoft.com...
> use
Q
QVZJUw
Thanks for the suggestions, found that the problem is related to a control
in the form and not related to the redemption coding.
> not expect?
> >use
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Y Redemption MessageItem SaveAs problem Outlook VBA and Custom Forms 8
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
J Outlook 2013 hanging for unknown reason Using Outlook 1
P Outlook hanging issue Using Outlook 0
David Trevose Hanging on Send Receive Using Outlook 2
M CDO hanging on Logoff Outlook VBA and Custom Forms 4
Diane Poremsky Data loss may occur during public folder migration Using Outlook 0
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
Diane Poremsky Add attachments and set email fields during a mail merge to email Using Outlook 0
D Outlook 2010 hangs during message send/receive Using Outlook 2
R People View Changes during search Using Outlook 2
H Corrupt arabic languge text during contact import Using Outlook 1
D Change To address when it is sent to a specific address during specfic time. Using Outlook 2
S Emails during business hours ONLY. Using Outlook 1
C crash during account setup - can't delete corrupted account/data file Using Outlook 13
P IMAP errors with AOL during sync Outlook VBA and Custom Forms 3
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
