Re: Read fields with Redemption
U
UmVpbmllcg
Hi Dmitry, can you please explain how to view this property
'PR_EMS_AB_HOME_MDB' in OutlookSpy? I feel I've looked everywhere but no luck.
thanks,
Reinier
"Dmitry Streblechenko" wrote:
> Message? These properties are not exposed by messages, they are exposed by
> the RDOAddressEntry objects (corresponds to the IMailUser object in MAPI)
> from teh GAL container.
> *Where* exactly do you see these properties when you are using MsgView? Can
> you see these properies in OutlookSpy?
> > Dmitry Streblechenko (MVP)
> "Joao Quaresma" <JoaoQuaresma> wrote in message
> news:4E0E9E4C-5CDD-4733-B076-C602FC7BEF4A@microsoft.com...
> > Hello,
> > I've used MsgView to read the saved message. In code i' am reading the
> > messages that are in a .pst file.
> > Joao Quaresma.
> >> How do you know that the field exists? Do you see it in OutlookSpy? How
> >> do
> >> you access these properties?
> >> Keep in midn that these properties are only exposed in the online (as
> >> opposed to cached) mode.
> >> "Joao Quaresma" <Joao Quaresma> wrote in
> >> message
> >> news:C77A23A8-B326-4DF0-B57B-096730D371A8@microsoft.com...
> >> > When I read the folowing fields with Redemption (&H8006001E -
> >> > PR_EMS_AB_HOME_MDB and &H39FE001E - PR_SMTP_ADDRESS) it returns an
> >> > empty
> >> > fiel, but the fields exist and have a value. Is there a problem with
> >> > Redemption when reading this fields?
> >> >> > Best regards,
> >> >> > Joao Quaresma.
Are you trying to read it from one of the GAL objects?
Have you tried to click IAddrBook button, then "Open Root Container"?
You can then browse to the GAL entry in question from teh GetHierarchyTable
/ GetContentsTable tabs of the IABContainer windows.
"Reinier" <Reinier> wrote in message
news:9DAFD607-3272-4E94-8ED0-80DE4296C0D0@microsoft.com...
> luck.
> thanks,
> Reinier
> > by
> > Can
> > > Hello,
> >>> > Joao Quaresma.
> > >> How
> > >> do
> > >> message
> > >> > empty
> > >>> >> > Best regards,
> > >>> >> > Joao Quaresma.
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
J From column changes when message is read Using Outlook 1
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
S Duplicate Read Receipt Using Outlook 4
K Read, unread, i'm losing clients! Using Outlook 1
