Redemption MessageItem SaveAs problem
  • Thread starter Thread starter Yevgen
Y
Yevgen
I have problem with Redemption SaveAs method for MessageItem object.
I'm saving items in olTNEF (1025) format. This problem occurs whits
mail items. I'm saving items fro Exchange Server mailboxes. When I'm
saving item of current Logged in to Outlook user "To" property is
saved ok, but when I'm saving items from not Logged in user mailbox
(Additional Exchange mailbox), "To" property is blank. But when I'm
opening this item in Outlook, "To" field is not empty. Also before
executing SaveAs method, I have checked item object and "To" property
is set correctly.
Please consult me with TNEF, also maybe it's a bug of SaveAs method in
Redemption library.
Thank you very much!
Are you using the MAPIUtils object (which is deprecated)?
Use RDOSession object instead: sets its MAPIOBJECT property to
Application.Session.MAPIOBJECT proeprty from OOM (if you work with it) or
call Logon.
You can then reopen the message using RDOSession.GetMessageFromId, then save
the rerurned message (RDOMail.Save).
Dmitry Streblechenko (MVP)
"Yevgen" <Jen.versh@gmail.com> wrote in message
news:ac9802e2-558b-460b-89bf-edaac10afbd8@s16g2000vbp.googlegroups.com...
> Hello,
> is set correctly.
> Redemption library.
On May 29, 12:18 am, "Dmitry Streblechenko" <dmi...@dimastr.com
> call Logon.
> OutlookSpy  - Outlook, CDO
> -"Yevgen" <Jen.ve...@gmail.com> wrote in message
> > Hello,
> > is set correctly.
> > Redemption library.
I have changed my code. So now I'm using RDOSession object instead of
MapiUtils.
Here is my code:
Dim oMsgItem As Redemption.RDOMail
Set oMsgItem = oRDOSession.GetMessageFromID(sItemEntryID)
oMsgItem .SaveAs sSaveAs, lType
Where lType = 1025 (TNEF)
But still I received the same problem. Items from Logged in user
mailbox has "To" field data and items from additional Exchange
mailboxes don't.
What the problem is? How can I fix it?
Hmmm... Redemption does not create the TNEF attachment itself, it rather
asks MAPI to do that.
How do you open and check the resulting TNEF files?
news:ae744426-c770-430f-ad1e-8edc3527337a@37g2000yqp.googlegroups.com...
> call Logon.
> save
> > Hello,
> > is set correctly.
> > Redemption library.
MapiUtils.
Here is my code:
mailboxes don't.
> > call Logon.
> > save
> >news:ac9802e2-558b-460b-89bf-edaac10afbd8@s16g2000vbp.googlegroups.com....
> > > Hello,
> > > is set correctly.
> > > Redemption library.
> MapiUtils.
> Here is my code:
> mailboxes don't.
> Thanks!
Hello Dmitry,
There is 2 variants how I'm opening these files.
1. Simple through text editor. and when you will compare 2 files you
will see that one of them contains "To:" information, another one not.
2. I have special application which open this files through Outlook.
Here is sample code:
Set oOlItem = oFolder.Items.Add(olPostItem)
Set oSafeItem = CreateObject("Redemption.SafeMailItem")
Set oOlItem = oOutlook.CreateItemFromTemplate(sSaveDir &
MESSAGE_TEMP_FILE, oFolder)
oOlItem.Save
Set oSafeItem.Item = oOlItem
oSafeItem.Import sSaveDir & MESSAGE_TEMP_FILE, iType
oSafeItem.Save
StrEntryID = oSafeItem.EntryID
Set oOlItem = Nothing
Set oSafeItem = Nothing
Set oSafeItem = oNamespace.Session.GetItemFromID(StrEntryID,
oFolder.StoreID)
oSafeItem.Display
So with both variants I have the same result. I think the easiest way
to check if the "TO:" information is saved is to compare 2 files with
any compare utility.
Thank you for helping.
Hmmm... Normally, the PR_DISPLAY_TO property is not saved at all since it is
computed from the contents of the recipeints table.
Does it work if you import teh TENF file using RDOMail rather than
MailItem/SafeMailItem, which may overwrite the imported recipients.
news:b515af38-c607-46a7-b990-c3aca1053ebf@u10g2000vbd.googlegroups.com...
> > or
> > call Logon.
> > save
> > > Hello,
> > > is set correctly.
> > > Redemption library.
> MapiUtils.
> Here is my code:
> mailboxes don't.
> Thanks!
Hello Dmitry,
oOlItem.Save
oSafeItem.Save
oFolder.StoreID)
oSafeItem.Display
I have tried to run Import function using Redemption.RDOMail object
and result is the same. For files from main Exchange folder "To:"
field is OK, but for files from additional Exchange folders "To:"
field is empty.
Do you have some ideas how I can solve this problem. Maybe somehow add
to information in TNEF file programmatic. When I'm saving object to
file, object contain "To:" information and I can get it.
> > > or
> > > call Logon.
> > > save
> > > > Hello,
> > > > is set correctly.
> > > > Redemption library.
> > MapiUtils.
> > Here is my code:
> > mailboxes don't.
> > Thanks!
> Hello Dmitry,
> oOlItem.Save
> oSafeItem.Save
> oFolder.StoreID)
> oSafeItem.Display
Hello Dmitry,
I have found nice function OpenTnefSreamEx to open Tnef files and
AddProps function to add different properties to it. How do you think,
is it possible to add "To:" field information using these functions?
If yes, can you give me a sample, how can I use these functions in
VisualBasic 6 program, because now I don't know how to do it even to
test this idea.
Thanks a lot!
"Yevgen" wrote:
> Hello,
> is set correctly.
> Redemption library.
I sent an updated version to your private address...
"Yevgen" <Yevgen> wrote in message
news:9CE0BDE6-9222-4C06-8C34-825155730CF7@microsoft.com...
> field is empty.
> > is
> > > rather
> > > > it)
> > > > or
> > > > call Logon.
> > > > then
> > > > save
> >> > > > Hello,
> > > > > object.
> > > > > I'm
> > > > > property
> > > > > is set correctly.
> > > > > in
> > > > > Redemption library.
> > > MapiUtils.
> > > Here is my code:
> > > mailboxes don't.
> >> > Thanks!
>> Hello Dmitry,
>> oOlItem.Save
>> oSafeItem.Save
> > oFolder.StoreID)
>> oSafeItem.Display
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
Q REDEMPTION HANGING during LOGON Outlook VBA and Custom Forms 2
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
K Trouble using SaveAs Outlook VBA and Custom Forms 3
J Outlook View Control SaveAs Outlook VBA and Custom Forms 1
A Item Save and Saveas events Outlook VBA and Custom Forms 9
