Item Save and Saveas events
  • Thread starter Thread starter Ashish
Ashish
How to differentiate between save and saveas a mail item. Item_Write call
for both cases and parameters for this function doesn't tell any difference
between two.
You'd most likely have to grab every single menu/toolbar entry that can
perform those commands and handle their Click events. For Outlook 2007 you'd
have to do the same thing with the ribbon also. This would apply not only to
the actions in Inspectors but also when the item is selected in an Explorer.
"Ashish" <akohli_2004@hotmail.com> wrote in message
news:O%23yhIOHrJHA.588@TK2MSFTNGP03.phx.gbl...
> difference between two.
I tried to capture the event for menu click but could not make it. Is there
any example available. I tried those which are in outlookcode.com but not
mentioned clearly
news:OZnPGbIrJHA.1240@TK2MSFTNGP02.phx.gbl...
> you'd have to do the same thing with the ribbon also. This would apply not
> only to the actions in Inspectors but also when the item is selected in an
> Explorer.
Not a menu click event, but the actual CommandBarButton objects that are
accessed from the menus/toolbars. So you need to instantiate a button
object, declared WithEvents for VB/VBA, representing say File,Save in the
Inspector menus. Then the same for File, SaveAs. And so on for every
possible way to perform those actions. You will need the id properties of
the buttons to grab them. Those can be picked up from a tool like
OutlookSpy.
There are plenty of code samples for using CommandBars.FindControl, which is
what you'd be using. It's up to you to find and grab all relevant
CommandBarButton objects.
news:uxMaMTJrJHA.1212@TK2MSFTNGP04.phx.gbl...
> mentioned clearly
Thanks. Yes Now i can capture the SaveAs action.
When we click on SaveAs a new "SaveAs" dislog box appear. How to capture
events for this "SaveAs" dislog box.
Means on saveas dialog there are 2 buttons "Save" and "Cancel". I want to
capture events when i click on these buttons.
news:O4JAMOKrJHA.3992@TK2MSFTNGP04.phx.gbl...
> OutlookSpy.
> is what you'd be using. It's up to you to find and grab all relevant
> >there any example available. I tried those which are in outlookcode.com
> >but not mentioned clearly
There are no events you can capture from that dialog.
news:eA%23w6fTrJHA.2484@TK2MSFTNGP03.phx.gbl...
Oh thats strange. Ok i'll do this task by different way. How to delete a
custom property from mail item.
Suppose i add a new field in mail item on exchange server and i want to
delete this field in outlook addin.
"urn:schemas:mailheader:X-MyField-Name"
IMessagePtr msgptr;
FieldsPtr Flds;
Flds = msgptr->Fields;
Flds->Item[ "urn:schemas:mailheader:X-MyField-Name" ]->Value = "field value"
In outlook addin i can get this field and its value through
HrGetOneProp(PR_TRANSPORT_MESSAGE_HEADERS.)
If i want to delete this field then i think it's possible using HrSetOneProp
But HrSetOneProp takes long value as property tag to set value for any
property. I dont know the long value for
urn:schemas:mailheader:X-MyField-Name. I used outspy/mfcmapi but it doesn't
show that field.
news:eA7dzqVrJHA.4592@TK2MSFTNGP06.phx.gbl...
Well, for one thing if an email is only within an Exchange organization that
property doesn't exist. Internal emails never have a
PR_TRANSPORT_MESSAGE_HEADERS property.
That property, when it does exist, is a text property (PT_STRING8) and there
are no "subfields" in it. It's just a string. You can parse it using string
functions and find that X-header and remove it using string functions.
news:eOPFtLerJHA.2136@TK2MSFTNGP06.phx.gbl...
> IMessagePtr msgptr;
> FieldsPtr Flds;
> value"
> HrSetOneProp .
> doesn't show that field.
Yes i did same. I get value for PR_TRANSPORT_MESSAGE_HEADERS and search
x_header when open item. Then get the value for x_header and remove it. It
works successfully. But when i close item i get value for
PR_TRANSPORT_MESSAGE_HEADERS and set the value of x_header which i
delete.This i do because when i open mail next time x_header should be
there. But this time the value is not set. I tried to set it in
item_close/inspector_deactivate event but value is not set. While if i debug
the program step by step the value is set. Please suggest from where i
should set it when close the item.
news:eg7PTThrJHA.6020@TK2MSFTNGP02.phx.gbl...
> that property doesn't exist. Internal emails never have a
> there are no "subfields" in it. It's just a string. You can parse it using
> string functions and find that X-header and remove it using string
> functions.
>> IMessagePtr msgptr;
> > FieldsPtr Flds;
> > value"
> > HrSetOneProp .
MAPI properties with a specific GUID are transformed into x-headers when the
item gets sent out, transformed by the message transport from a property
into part of the header. That's the only time that happens. You can grab and
existing PR_TRANSPORT_MESSAGE_HEADERS string and manipulate it using string
functions to add something and write it back. That's about it.
Why not just create an Outlook UserProperty, or if you don't want it to be
available to users create a named MAPI property and use that?
news:OiYZUbhrJHA.528@TK2MSFTNGP06.phx.gbl...
> debug the program step by step the value is set. Please suggest from where
> i should set it when close the item.
D Save Sent Item to Using Outlook 0
JohnP Shared Mailboxes "Save Sent Item" Using Outlook 2
R How do I 'Save Copy of Sent Item to Folder' for a Shared Mailbox Outlook VBA and Custom Forms 9
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
T PR_MESSAGE_CLASS is reset when calling Save() on item Outlook VBA and Custom Forms 4
G Outlook Contact Item.Restrict where FullName is NULL Outlook VBA and Custom Forms 3
T Outlook365 search item listed as "potential matches" can't be opened Using Outlook 0
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
T Pictures degrade each time an Outlook item is edited and re-saved Using Outlook 1
GregS Many Sent Item folders Using Outlook 3
B Select / activate first email item in the searched query Using Outlook 1
N "Discussion" item Using Outlook 3
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
M Shortcut to another outlook item Using Outlook 0
Cdub27 Your changes to this item couldn't be saved because Server Denied Operation (HTTP 403 Forbidden) Using Outlook 1
G Outlook item link Using Outlook 0
Jeanne Goodman Delete Calendar Item Bypassing Deleted Items folder Outlook VBA and Custom Forms 2
Diane Poremsky Display the Created Date field of any Outlook item Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
J "This item has been changed still want to delete it" message Using Outlook 3
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
D Shared Mailbox with mail item marked as "private" Using Outlook 0
