Item.Recipients for Task Assignment on Send
Zyzzx
Outlook 2013 32 bit
The following is the beginning of my VBA code, which has the core function to make sure the sender verifies that the information is not sensitive when sending emails to a recipient on from a list. I have built this from this forum and a few other forums. Currently, it works awesome for sending email; however, when I send a task with an assignee, it fails at "Set Recipients = Item.Recipients" (located 3rd line from the bottom) with a "Run-time error '438': Object doesn't support this property or method. In the end, I would like to get the recipients of all items, such as both mail and task items, so I can verify them before sending. I have sent appointment/meeting requests with no issues. Is this an achievable goal? I feel it should be. I hope this is enough information to get us started. I appreciate the help in advance.
Dim lbadFound As Boolean
Dim send As String
Dim Recipients, Recip, RecipList As String
Dim i As Integer
Dim aFile As String
Dim enviro As String
Dim n As Integer
enviro = CStr(VBA.Environ("USERPROFILE"))
aFile = enviro & "\AppData\Roaming\Microsoft\Outlook\MacroDebug.txt"
n = FreeFile()
Close #n
Dim myNamespace As Outlook.NameSpace
Set myNamespace = Application.GetNamespace("MAPI")
Zyzzx
Outlook 2013 32 bit
Dim send As String
Dim KaceCommands, Recipients, Recip, RecipList As String
Dim i As Integer
Dim aFile As String
Dim n As Integer
n = FreeFile()
Close #n
strTemp1 = "False"
Submit = ""
Priority = ""
Impact = ""
Status = ""
Submitter = ""
Owner = ""
Categories = ""
KaceCommands = ""
lbadFound = False
Sender = myNamespace.CurrentUser
EmailRegKey = "HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\EmailList"
ITRegKey = "HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\ITMembers"
TicketRegKey = "HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\TicketEmails"
EmailList = RegKeyRead(EmailRegKey)
ITList = RegKeyRead(ITRegKey)
TicketList = RegKeyRead(TicketRegKey)
Recip = Recipients.Item(i)
RecipList = RecipList & " " & Recip
If InStr(VBA.LCase(ITList), VBA.LCase(Sender)) >= 1 And InStr(VBA.LCase(TicketList), VBA.LCase(Recip)) >= 1 Then
TicketSubmission.Show
If InStr(VBA.LCase(TicketList), VBA.LCase(Recip)) >= 1 And InStr(Item.Body, "-+-+- Please reply above this line to add a comment -+-+-") = 0 Then
PriorityDialog.Show
Item.Body = "@priority=" & Priority & vbCrLf & Item.Body
If InStr(VBA.LCase(EmailList), VBA.LCase(Recip)) >= 1 Then
lbadFound = True
Exit For
Next i
If Impact <> "" Then
KaceCommands = KaceCommands & vbCrLf & "@impact=" & Impact
If Status <> "" Then
KaceCommands = KaceCommands & vbCrLf & "@status=" & Status
If Submitter <> "" Then
KaceCommands = KaceCommands & vbCrLf & "@submitter=" & Submitter
If Owner <> "" Then
KaceCommands = KaceCommands & vbCrLf & "@owner=" & Owner
If Categories <> "" Then
KaceCommands = KaceCommands & vbCrLf & "@category=" & Categories
If KaceCommands <> "" Then
Item.Body = KaceCommands & vbCrLf & vbCrLf & Item.Body
Open aFile For Output As #n
Print #n, "lbadFound = " & lbadFound & vbCrLf; "RecipList = " & RecipList & vbCrLf; "Sender = " & Sender
Close #n
If lbadFound Then
ExportComplianceCheck.DialogBox = "One or more of the recipients requires prior Export Compliance approval to receive technical data." & vbCrLf & vbCrLf & "Does this email contain unauthorized technical data?"
ExportComplianceCheck.Show
If strTemp1 = True Then
Cancel = True
You'll need to check if it's a task request and get the associated task time to get the recipient.
Dim recips As Outlook.Recipients
Dim recip As Outlook.Recipient
If Item.Class = olTaskRequest Then
Set mytaskreqItem = Item
Set myNewTaskItem = mytaskreqItem.GetAssociatedTask(True)
Debug.Print myNewTaskItem.Subject
Set recips = myNewTaskItem.Recipients
For Each recip In recips
Debug.Print recip
If Not Item.Class = olTaskRequest Then
'get the recipients
end if
Zyzzx
Outlook 2013 32 bit
So...with the following sequence, I get the name of the recipient in the immediate window, but it fails at the last line, of what is pasted in this post, with "Run-time error '91': Object variable or With block variable not set" and I am not sure why. Will you assist, please?
Dim send As String
Dim KaceCommands, RecipList As String
Dim i As Integer
Dim aFile As String
Dim n As Integer
n = FreeFile()
Close #n
strTemp1 = "False"
Submit = ""
Priority = ""
Impact = ""
Status = ""
Submitter = ""
Owner = ""
Categories = ""
KaceCommands = ""
lbadFound = False
Dim Recips As Outlook.Recipients
Set Recips = myNewTaskItem.Recips
For Each recip In Recips
Debug.Print recip
Set Recips = Item.Recipients
Debug.Print recip
For i = Recips.Count To 1 Step -1
recip = Recips.Item(i)
you'll need to put the code inside the if's, like this - i don't know if it's better to use for each or count*** - but task requests should only have one recipient, no need to loop. If would be nice if you could jump out and reuse those 3 if statements but at the moment my brain isn't seeing a way, short of putting them in a function.
PriorityDialog.Show
lbadFound = True
Exit For
*** if you were deleting then you need to count backwards for sure.
Of course, you'll repeat that for the Not Tasks loop - both loops would go after the Registry stuff, basically where those 3 if statements are now.
Zyzzx
Outlook 2013 32 bit
I don't suppose you know of a way to simplify this:
If Item.Class = olTaskRequest Or Item.Class = olTaskRequestAccept Or Item.Class = olTaskRequestDecline Or Item.Class = olTaskRequestUpdate Then
Set Recips = myNewTaskItem.Recipients
Debug.Print "TaskItem = "; recip
If Not Item.Class = olTaskRequest Or Item.Class = olTaskRequestAccept Or Item.Class = olTaskRequestDecline Or Item.Class = olTaskRequestUpdate Then
Debug.Print "NonTaskItem = "; recip
Oh...also, I was able to keep these as is without putting the "For Each recip In recips" sequence in each one. It stores correctly. Do you know if I will run into issues going to the 2010 Outlook with this macro?
Zyzzx
Outlook 2013 32 bit
Ugh...I have ran into another problem. I added a debug.print Item.Class and it shows " 51 " in the immediate window, without quotes. So, it starts and ends with a space. Oddly, it does go through the first if and second if. What could be wrong? I am getting stuck at the "Set Recips = Item.Recipients" in the second if statement.
Debug.Print Item.Class
It should be fine in 2010 - this is basic stuff and should work in all versions currently in use.
As for simplifying, it might not win any awards, but it works in a quickie test -
If Left(TypeName(Item), 4) = "Task" Then
If Not Left(TypeName(Item), 4) = "Task" Then
I think the problem here is NOT - you need one with each - although the double negative is more prone to fail. (B is not A and A is not B so "if not A or if not B" will get both A and B.)
This might work - but i like my simpler Typename. :)
If Not (Item.Class = olTaskRequest Or Item.Class = olTaskRequestAccept Or Item.Class = olTaskRequestDecline Or Item.Class = olTaskRequestUpdate) Then
or this
If Not Item.Class = olTaskRequest And Not Item.Class = olTaskRequestAccept And Not Item.Class = olTaskRequestDecline And Not Item.Class = olTaskRequestUpdate Then
(i didn't test either of those)
C Persist all recipients on Item forward event Outlook VBA and Custom Forms 5
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
T Pictures degrade each time an Outlook item is edited and re-saved Using Outlook 1
GregS Many Sent Item folders Using Outlook 3
B Select / activate first email item in the searched query Using Outlook 1
N "Discussion" item Using Outlook 3
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
M Shortcut to another outlook item Using Outlook 0
Cdub27 Your changes to this item couldn't be saved because Server Denied Operation (HTTP 403 Forbidden) Using Outlook 1
G Outlook item link Using Outlook 0
D Save Sent Item to Using Outlook 0
Jeanne Goodman Delete Calendar Item Bypassing Deleted Items folder Outlook VBA and Custom Forms 2
Diane Poremsky Display the Created Date field of any Outlook item Using Outlook 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
J "This item has been changed still want to delete it" message Using Outlook 3
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
D Shared Mailbox with mail item marked as "private" Using Outlook 0
Diane Poremsky Change Item Count on All Folders in a Data File Using Outlook 0
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
V Locate item Account Outlook VBA and Custom Forms 7
JohnP Shared Mailboxes "Save Sent Item" Using Outlook 2
D After Moving or Deleting Open Item - Meeting Requests Using Outlook 4
S Item Add Event fires intermittently Outlook VBA and Custom Forms 3
