Redemption.RDOSession logon() stops emails sending-they stay in Ou
N
Nabil
I have a problem with my Outlook Addin, I'm using VSTO and Outlook 2007. I
am also using redemption for some of my events.
' Declarations
Public WithEvents myRDOsession As Redemption.RDOSession
in ThisAddIn_Startup() I have the following code
myRDOsession = New Redemption.RDOSession
myRDOsession.Logon()
The above line i.e. the logon() stops emails going out. Any email that I
send stays in the Outbox folder. If I comment out Logon() then emails go out
without a problem. I obviously need the RDOSession to be logged on.
I've tried to use myRDOsession.LogonExchangeMailbox(gstrUserID, "") which
works and email send correctly but I then won't have access to all the Stores
(myRDOsession.Stores will not contain my PST file Stores)
Has anyone come across this problem before, this is really starting to bug
me!!!
Any help will be greatly appreciated!
Nabil
K
Ken Slovak - [MVP - Outlook]
In an addin assign NameSpace.MAPIOBJECT to RDOSession.MAPIOBJECT instead of
using the Logon() method.
"Nabil" <Nabil> wrote in message
news:E1AA8306-E989-4064-8611-12DE4925E1E3@microsoft.com...
> Hi,
> I
> ' Declarations
> out
> Stores
> me!!!
> Thanks
> Nabil
N
Nabil
Thanks Ken, I tried what you suggested but it hasn't solved my problem.
Emails are still waiting in my Outbox.
myRDOsession.LoggedOn reports as true
Any other suggestions?
Nabil
"Nabil" wrote:
> Hi,
> ' Declarations
> me!!!
> Thanks
> Nabil
K
How are you sending the emails?
If they are staying in Outbox after being sent from the UI then something is
messing with the items there, which will cancel the send.
If you are sending using Redemption, for example, rdoItem.Send(), then you
might need to initiate a SyncObjects() call to start the transport. I
usually use something like NameSpace.SyncObjects(1).Start().
news:B11249B1-B5F4-4E73-BBC9-0A30E2134BA6@microsoft.com...
> Thanks
> Nabil
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Y Redemption MessageItem SaveAs problem Outlook VBA and Custom Forms 8
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
Q REDEMPTION HANGING during LOGON Outlook VBA and Custom Forms 2
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
N How to know the email sender (windows logon profile) from a Shared Mailbox Using Outlook 2
makinmyway Help Using Windows Desktop Search to Index Outlook PST of another User Logon Using Outlook 14
R "business contact manager logon failure server is in single user mode" - HELP! BCM (Business Contact Manager) 4
L Exchange Management Console - Initializtion failed on Logon Failure: unknown username or bad passwor Exchange Server Administration 4
