Should I switch to redemption
E
escamoteur
I'm programming my Addin for Outlook2007. After running against several restrictions I know think about switching to Redemption and
RDO, but it seems that it's a oneway road. If I doo I have completely to switch as it seems like RDO Objects cannot be casted to
Outlook Object Model objects.
What are your experiences??
Best
Tom
N
Nabil
No, it's not a 1 way road.
You are correct, most RDO objects cannot be casted to Outlook objects,
however, most objects such as Folders, messages... etc have EntryIDs which
you can use to get the Outlook Object
For example
Private gFolder_CurrentOutlookFolder As Outlook.Folder = Nothing
Private gFolder_CurrentOutlookRDOFolder As Redemption.RDOFolder = Nothing
gFolder_CurrentOutlookFolder = explorer_ActiveExplorer.CurrentFolder
gFolder_CurrentOutlookRDOFolder =
myRDOsession.GetFolderFromID(gFolder_CurrentOutlookFolder.EntryID)
As you can see above, I'm using the EntryID of an Outlook Folder to get an
RDO folder.
NOTE: Outlook events are so unreliable it is unbelievable
Good luck
E
escamoteur
Yes, I realized the way over the ItemID, but that's a bit arkward.
So you say Remdemtion Events are more reliable?
You can recommend the use of redemption?
How do I get an Redemption Item from the item that I get from a FormRegion Object?
Best
Tom
"Nabil" <Nabil> schrieb im Newsbeitrag news:002CFC70-AE81-4BE0-A534-93B4B0AB0ABA@microsoft.com...
> Hi,
> For example
> RDO folder.
> Good luck
N
Nabil
See below
I think it's just as awkward as casting to be honest
A lot more reliable, not 100% reliable still
If your addin is event driven then yet, definately.
Sorry, I have very little experience with outlook FormRegions.
E
escamoteur
Thanks a lot.
The FormRegion is not important. I can get an Item Object from the region or from the inspector object. Normally I would cast this
Object to e.g. Outlook.TaskItem. How can I cast this to the appropriate RDO Object?
Also the difference between a cast and the ItemID is, A cast does not call a function that has to lookup an item. So performance is
also a point
Best
TOm
"Nabil" <Nabil> schrieb im Newsbeitrag news:C76E3334-E789-49C9-8886-22A137131267@microsoft.com...
> See below
N
Nabil
See below
Having had a quick look, I don't know how you'd cast a TaskItem. I know
that for mail items you do this
Dim myRDOMail As Redemption.RDOMail
Dim myMailItem As Outlook.MailItem
myRDOMail = myRDOsession.GetMessageFromID(myMailItem.EntryID)
Have a look at the following link which may help you and also have a alook
throught the FAQ section on the redemption website
http://www.dimastr.com/redemption/rdo/RDOTaskItem.htm
> also a point
> Best
> TOm
> > See below
K
Ken Slovak - [MVP - Outlook]
You wouldn't cast it, you'd get the Outlook.TaskItem and get its EntryID and
get an RDO item from that.
"escamoteur" <mail@burkharts.net> wrote in message
news:9B431977-28E4-407D-B9E0-62DF21226D7B@microsoft.com...
> Thanks a lot.
> or from the inspector object. Normally I would cast this Object to e.g.
> a function that has to lookup an item. So performance is also a point
> Best
> TOm
K
I've used a mix of Outlook object model and RDO objects in almost every
program I've written probably for the last 8 or 9 years. Even with Outlook
2007's extended object model there are many things you can do with RDO that
you can't with the OOM. And if you have to support older versions the new
object model stuff isn't there.
I highly recommend RDO, but your mileage may vary.
news:DAE92374-3F7E-4C90-81A3-EFCC3E9D874E@microsoft.com...
> Hi,
> restrictions I know think about switching to Redemption and RDO, but it
> seems like RDO Objects cannot be casted to Outlook Object Model objects.
> Best
> Tom
SvenC
Hi Tom
> and RDO, but it seems that it's a oneway road. If I doo I have completely to switch as it seems like RDO Objects cannot be casted
I use RDO in some modules. It works great. And the big advantage over CDO 1.21
or OOM is: if you have a problem, Dmitry is really good at understanding your
problem and providing a solution. At least, that is how I memorize it from the past,
because I do not have any issues any more ;-)
While you are correct about the casting, Nabil provided some solutions.
Another option is to use the MAPIOBJECT property provided by most OOM or
CDO objects. Search for MAPIOBJECT on http://www.dimastr.com/redemption
to find samples how to use that.
SvenC
E
escamoteur
Thanks Ken! As always you have a sound answer.
How do you decide what to do with RDO and what with OOM? Or do you do almost all in RDO?
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:OeV4aZhMKHA.2036@TK2MSFTNGP06.phx.gbl...
> > Hi,
> > Best
> > Tom
K
It depends on what versions of Outlook I'm supporting for that code mostly.
When I'm supporting Outlook 2000 and up I use a lot more RDO stuff because
of the more limited Outlook object model than I would if I was only
supporting Outlook 2007.
In the real world I've yet to see a project that was only for Outlook 2007
(except for my book stuff). Mostly lately I've been asked to support Outlook
2003 and up, although I'm still supporting 2000 for some new projects. So
that partly determines what I'd use.
Some things you can't do even with PropertyAccessor, such as reading large
property streams or things restricted by MS for "Outlook business logic"
reasons. Those are candidates for RDO, as are things still not exposed by
the object model. Some of the really hairy undocumented stuff I do is almost
pure RDO and Win32 API/PInvoke code, so it all depends and will vary from
project to project and even from class to class.
news:us7ebwhMKHA.3384@TK2MSFTNGP04.phx.gbl...
> almost all in RDO?
> Best
> Tom
Dmitry Streblechenko
You can either use RDOSession.GetMessageFromID to retrieving RDOMial given
an entry id.
Or you can use the Safe*Item family of objects - simply ste the
SafeMainItem.Item property to an instance of the Outlook's MailItem object.
Dmitry Streblechenko (MVP)
> Hi,
> Best
> Tom
E Should I switch to redemption Outlook VBA and Custom Forms 11
E Should I switch to IMAP? Using Outlook 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
F Which upgrade should I go for and how do I do it please? Using Outlook 2
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Unhandled exception: picture argument should be an image BCM (Business Contact Manager) 0
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
R Which event should i advise? Outlook VBA and Custom Forms 2
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
Q Re: Detecting whether a toolbar is and should be shown Outlook VBA and Custom Forms 5
Commodore Automatic switch between working offline/online Using Outlook 4
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
J VBA to switch Outlook online/offline Outlook VBA and Custom Forms 4
George Simpson "Switch to HTML" in Outlook 2016 notes field Using Outlook 1
B Switch template with account Outlook VBA and Custom Forms 3
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
B Outlook 2010: using /altvba switch Using Outlook 1
T How to determine when I switch from mail to calendar etc. Using Outlook 9
wisedave Switch from POP3 over to IMAP Using Outlook 3
K Can Outlook be launched with the /cleanreminders switch multiple times? Using Outlook 2
W How to switch my list view back to normal view Using Outlook 1
M Switch Mail format Outlook VBA and Custom Forms 6
U Using /a switch to send multiple files? Outlook VBA and Custom Forms 1
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
