Redemption Foldes.Add doesn't work
  • Thread starter Thread starter escamoteur
E
escamoteur
I tried this here. The Store is created, fine, but the folder is not created although the returned RDOFolder is not null
I use Outlook 2007
RDOSession Session = new RDOSessionClass();// CreateObject("Redemption.RDOSession");
//Use the MAPI session from Outlook Object Model
Session.MAPIOBJECT = theApp.Instance.Application.Session.MAPIOBJECT;
RDOStore Store = (RDOStore) Session.Stores.AddPSTStore(path, 2, "ArtistsOrganizer");
RDOFolder folder = Store.RootFolder.Folders.Add("Opportunities", "IPM.Task.ArtistsOrganizer.BO");
REplace the line
with
RDOFolder folder = Store.IPMRootFolder.Folders.Add("Opportunities",
Note that root folder of any store is not visible - Outlook creates
invisible and search folders there.
What you need is the root IPM folder (which is a subfolder of the root
folder).
You can look at the folders in OutlookSpy - click IMsgStore button in the
OutlookSpy toolbar, then click "Open Root Container" and go to the
GetHierarchyTable tab.
Dmitry Streblechenko (MVP)
"escamoteur" <mail@burkharts.net> wrote in message
news:B3110896-7970-4CB6-9E9F-BFDFBAF698A4@microsoft.com...
> I use Outlook 2007
> RDOFolder folder =
Does the GetRootFolder Method of OOM return in reality the IPMRootFolder?
Because this here was my former code
theApp.Instance.Application.Session.AddStoreEx(,Microsoft.Office.Interop.Outlook.OlStoreType.olStoreUnicode);
Outlook.MAPIFolder rootFolder = (Outlook.Folder) AO_Store.GetRootFolder();
rootFolder.Name = ;
//Create Folders
BO_Folder = (Outlook.Folder)rootFolder.Folders.Add("Oportunities", Outlook.OlDefaultFolders.olFolderTasks);
And that worked
"Dmitry Streblechenko" <dmitry@dimastr.com> schrieb im Newsbeitrag news:eoCreVjMKHA.1312@TK2MSFTNGP05.phx.gbl...
> REplace the line
> with
> folder).
>> I use Outlook 2007
> > RDOFolder folder =
Yes, Store.GetRotFolder returns the IPM root folder, not the topmost folder
in the store.
news:DE8BBC61-B147-46A6-BAB2-60ED5A1D3365@microsoft.com...
> rootFolder.Name = ;
> //Create Folders
> BO_Folder =
> And that worked
> > REplace the line
> > with
> > folder).
>>> I use Outlook 2007
> >> RDOFolder folder =
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Y Redemption MessageItem SaveAs problem Outlook VBA and Custom Forms 8
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
Q REDEMPTION HANGING during LOGON Outlook VBA and Custom Forms 2
P Redemption not working on OL2007 Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 0
T Add Account Using Outlook 1
