Problems with Outlook.Recipient.Resolve
  • Thread starter Thread starter JoD
JoD
I am using Microsoft Office 2007 to create Outlook calendar appointments from
Access. I can successfully do this with one exception: I have a series of
calendars with similar names - the last portion of the name, for the 16
calendars, ranges from SEMI-1 to SEMI-16. With the code below, the .Resolve
method is unsuccessful for only the calendar ...SEMI-1.
I have verified that the name correctly matches the name of the calendar.
Any suggestions would be appreciated (including renaming that calendar, if
necessary!)
Dim objNameSpace As Outlook.NameSpace
Dim objRecipient As Outlook.Recipient
Dim objFolder As Outlook.MAPIFolder
Dim objItems As Outlook.Items
Dim objAppt As Outlook.AppointmentItem
Dim myCalendar, strStart, strShortTime As String
'find and delete the corresponding calendar appointment
Set objOutlook = CreateObject("Outlook.Application")
Set objNameSpace = objOutlook.GetNamespace("MAPI")
If Len(Trim(Nz(Me!cboCalendar.Column(0)))) > 0 Then ' proceed, should be
an appointment
myCalendar = strCalendar
Set objRecipient = objNameSpace.CreateRecipient(myCalendar)
' check calendar name
objRecipient.Resolve
If objRecipient.Resolved Then
' create start date/time
strStart = strExamDate & " " & strStartTime
strStart = Format(strExamDate & " " & strStartTime, "mm/dd/yyyy
hh:mm AMPM")
' set values for objects and delete appointment
Set objFolder =
objNameSpace.GetSharedDefaultFolder(objRecipient, olFolderCalendar)
Set objItems = objFolder.Items
Set objAppt = objItems.Find("[Start] = """ & strStart & """")
If objAppt Is Nothing Then
MsgBox ("This appointment was not found in Outlook")
objAppt.Delete
Set objAppt = Nothing
'Now display appropriate message
MsgBox ("Appointment deleted from Outlook")
Set objItems = Nothing
Set objFolder = Nothing
MsgBox ("No appointment deleted, could not resolve calendar name")
MsgBox ("No appointment deleted, no existing appointment")
'Release the object variables
Set objNameSpace = Nothing
Set objRecipient = Nothing
Set objOutlook = Nothing
Try prefixing each one with "=" to force Outlook to perform an exact match
on the name when it tries to resolve.
Sue Mosher
"JoD" <JoD> wrote in message
news:A2BF1308-D340-4B87-A5C8-447232968165@microsoft.com...
> from
> .Resolve
> necessary!)
> be
> an appointment
> hh:mm AMPM")
> Set objFolder =
> Else
> objAppt.Delete
> End If
> Else
> name")
> End If
> Else
> End If
Could you kindly show me an example of what you mean? I'm not sure where the
"=" would go.
> > Sue Mosher
> >from
> > .Resolve
> > necessary!)
> > be
> > an appointment
> > hh:mm AMPM")
> > Set objFolder =
> > Else
> > objAppt.Delete
> > End If
> > Else
> > name")
> > End If
> > Else
> > End If
Set objRecipient = objNameSpace.CreateRecipient("=" & myCalendar)
Sue Mosher
news:32E2203C-7CFA-44C4-AAD7-BC9F35E49F70@microsoft.com...
> the
> "=" would go.
> Thanks!
> > match
> > >from
> > > of
> > > .Resolve
> > > calendar.
> > > if
> > > necessary!)
> > > should
> > > be
> > > an appointment
> > > "mm/dd/yyyy
> > > hh:mm AMPM")
> > > Set objFolder =
> > > Else
> > > objAppt.Delete
> > > End If
> > > Else
> > > name")
> > > End If
> > > Else
> > > End If
K Outlook for Mac problems Using Outlook 0
P outlook.com problems Using Outlook 0
D Outlook and Icloud problems Using Outlook 0
E Outlook 2010 network printing problems Using Outlook 4
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J problems with viewing aol emails in Outlook Using Outlook 3
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C migrating from Windows Live Mail over to Outlook 2010 Problems ... Using Outlook 2
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
S Outlook 2010 and certificate problems Using Outlook 9
M Several Problems using Outlook Using Outlook 3
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
